Question about iLO DVDR04
My DVDR04 will not read any DVD+R disk.
When ever I put in a DVD+R disk, the DVDR04 just ejects it. I hold it in and it will stay but then when I click "Record" it will not record and gives me an error symbol. I've tried three different types of DVD's.
  • Anonymous Apr 24, 2009
    I also have the same problem with my DVDR04.
  • auntthuy2 May 01, 2009
    I also have the same problem too
You are using the right type Plus (+)R. So, I'd think, the unit is deffective. When I bought mine I had to take back to Walmart, and get it a different one because it was stopping me from recording my own recorded VCR tapes.
Posted on Jun 18, 2009
I had the same problem. On the front of the drive tray is a face plate. You can "pop" off the face plate by lifting up on it. On the back are two screws with springs attached. If you pull out on the face of the tray you will feel the springs attached. I loosened the screws to allow the tray to retracked further into the drive. This worked for me. If I could only get it to play my DIVX movies again now.
Posted on Jun 26, 2009
DVD stuck in my Panasonic DMR-E30
Hi Rock.
I had the same problem like this on my machine. The best way to fix it is to turn the machine off completely and hold on the eject button then turn the power on. You want the first thing the player does is to eject the disk without trying to read it first.
I hope it works let me know if it doesn't and i'll try and recreate the problem on my player and see what i can do to get the disk out.
The last resort is to manually take the disk out but lets cross that bridge if my suggestion above doesn't work.
Thanks
smeags.
Feb 18, 2008 | Panasonic DMR-E30 DVD Recorder
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Hitachi mini dvd cam will not eject disc, will not read, will not write, will not record. Also cannot read mini disc on Windows Vista, is there a driver for either of these issues?
This has happened to me many times. The disk has an error (they alway do).
1: Turn it off.
2: Attatch power connection.
3: Hold down eject button.
4: It should say: "DISK ACCESS"
5: It may take a long time, but put it down in this state and leave it for as long as it may take.
6: Later on, it will eject the disk.
7: Discard of this disk, it's nothing but trouble.
Aug 18, 2010 | Hitachi DZ-MV230A DVD Camcorder
My ilo dvd R/P will not record and keeps saying invalid disk,
TILO DVDR04 PLAYER RECORDER THE DVD RECRDER IS IT SPECIFIC TO THE DVD RO4 CAN IT BE REPLACED WITH ANY PLAYER BURNER IT SEEMS TO PLAY NORMALLY.
Mar 08, 2010 | iLO DVDR04
CD Tray will not open, on playback often says insert disk when a cd is entered.
Straighten a paper clip. There is a small hole the size of the paper clip on the front of most disk devices. Put the clip into the hole and the drawer should open.
read ya,
Zee
Dec 29, 2009 | iLO DVDR04
IMac5,1 DVD-R won't eject.
restart mac and hold down the mouse after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
Hope this helps.
Oct 30, 2009 | Computers & Internet
After recording on a disk from my DVDR04 the disk will not play in my other DVD what type a disk do i need
Well first of all I think its not a disk problem but the file name. You know the .mpg or .mpeg sort of thing. Read the DVD manual and figure out what under what file name you should burn your files next time. Good luck and let me know if that works
Oct 02, 2008 | Televison & Video
No eject/reads hello thats all
Is there a small hole under the tray? Use a straightened paper clip and piu it in there and push, it should manually push the tray out. If there is anything on the DVD that looks like a computer program, the DVD may be trying to read it as a BIOS upgrade. The spindle motor may be bad too as the DVD is waiting for the platter to spin up to read it and is timing out.
Mar 03, 2008 | iLO DVDR04
ILo DVDR04 Recorder
your dvd writer is bad you will have to replace it believe me i now what im talking about i have went through 4 ilo's did the same thing plus 100's of differnt name brand dvd's
Feb 15, 2007 | iLO DVDR04
iLO DVDR04 Logo
221 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
