Question about Sharp AR-507 Copier
Sharp AR 507 has a code L3-00 Scanner will not retun home in time
The scanner comes ot and coming in to home makes a zipping sound then slowly drags to home throwing L3-00 everytime. I tried adjusting the bracket spacing behind the motor all three level notches. The wires were not toched they remain factory defalt. its been a headache any possible tips?? need help thanks
  • 1 more comment
  • Anonymous Mar 14, 2009
    thanks will try
  • xerosatlanti Apr 27, 2009
    my copier display L3.00 immediatly I on it , and the scanner light does not move at all, I have tried to clean the photo home sensor but it still continue and I changed it still the same
  • Anonymous May 01, 2009
    How do I reprogram scatterd program I change scanner motor setup value from 2 to 0, after the copier started showing L3.00 , and when I tried to change it back it refuse. it keep showing L3.00 immediatly, I put the machine on.
    New Friend:
  • 91 Answers
It could be the Mirror Home Position Sensor malfunction, it's located at the upper left section of the upper frame, if the copy lamp is in its home position, there's a lever/part of the copy lamp that actuated this photo sensor. Try clean that tiny gap with a hand blower, if L3 still occur then you should change it.
Posted on Mar 13, 2009
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Error code e7-11 comes up on my sharp mx-m260 e7-11
An E7-11 is an
Improper CCD white reference plate
reading level for copy lamp lighting
You can try taking the glass off and cleaning the white strip under the **** glass, the mirrors and the lamp. If that doesn't work it could be the flat cable coming loose of the scanner or the CCD going bad.
Oct 18, 2011 | Sharp MX-2300N Color Copier
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Jan 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
I turned the copier off completely, then turned it back on -- it seemed to resolve the L3-00 issue.
Apr 30, 2009 | Sharp AR-507 Copier
Error CE while scanning though N/W in Sharp AR M-205
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
Mar 19, 2009 | Sharp AR-M205 Copier
L1 is flashing and the photocopier is not working
.****MAKE SURE THE POWER IT OFF AND UNPLUGGED FROM THE WALL FIRST *******
This is a scanner problem - didn't leave or come back to home, scan overload or cable off or drive problem. Try to unlock the scanner from it position ( Remove platen glass and move the scanner unit from it position)
Jan 20, 2009 | Sharp AR-5316 Advanced Digital Imager...
Need for help.
C1-00 means MC unit malfunction. Try turning the copier off. Wait 30 seconds and turn it back on again and see if goes away.
If it comes back you should contact a technician in your area.
Jul 17, 2008 | Sharp AR-507 Copier
Sharp AR-507 Copier Logo
448 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
