Question about Cell Phones
My nokia n96 mobile key pad 1234567890*# this keys are not working after the display light off or when lock unlock the phone please solve my problem
    Master:
  • 368 Answers
Hello:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Apr 20, 2013
SOURCE: Phone locked! Please Contact service center!
Haier D1000
Posted on Mar 25, 2009
Murphybanton
  • 2004 Answers
SOURCE: forgot the key gaurd lock code
Try 12345 or visit http://www.unlockme.co.uk/master.php
Enter your imei number to generate master reset code.
Cheers. rate fixya
Posted on Jun 07, 2009
plaiboi_rulz
  • 139 Answers
SOURCE: touch not working for contact shortcut
Yoou can simply restart your handset sir. ;)
Posted on Dec 13, 2009
persia27
  • 76 Answers
SOURCE: My nokia 6300 phones back light is not working
does your phone accidentally fell on a hard surface? if that is so, then, the board itself is loose thats why you have problems with the backlights. go to your nokia center and have it fixed. its just a minor repair.
Posted on Nov 12, 2010
SOURCE: my nokia 2700 classic mobile
Hello Sharma,
Switch off the nokia classic 2700 phone. Remove the battery for 30 minutes.Reinsert the battery and switch on the nokia classic 2700 phone. Enter the default code 12345 or 00000. Your nokia classic 2700 phone will be unlocked.
or
Try the Master Code : 4625042566
Posted on Jun 09, 2011
Testimonial: "thnx for your solution....but i have already unlocked the phone by removing the sim and then entering default code 12345... thnx."
What is the restriction code for nokia x2-02
The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove Sim card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
(master code) is a 10 digit code, based on the phones IMEI number.
(I can NOT give you the master code - SO DON'T ASK ME FOR IT !!!!!!!)
Eg. To remove restriction on lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
Please NOTE that these codes could be used with care! A user told me that it's only possible to type in about 5 different codes on each lock! Then something bad will happen ..therefore be careful
Jun 03, 2013 | Cell Phones
Tip
Codes of 5130
<b> Nokia 5130 Mobile Unlock <br /></b> <br /><br />*#06# for checking the IMEI (International Mobile Equipment Identity) for Nokia 5130 To view Week and Year of manufacture enter *#3283# [*# D A T E #] <br />The last two digits are the year. If the year is 95, the first two digits are the month. For 96 the first two digits are the week of the year. <br /><br />To view the software version on Nokia 5130 enter *#170602112302# or *#9999# <br />On newer phones, the code has been changed to *#682371158412125# <br /><br />All Nokia phones (Nokia 5130 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) <br /><br />The main code used in Nokia 5130 phones is : <br />#pw+(master code)+Y# <br />This code is able to check, activate or remove Sim card restriction (SP-lock). <br />Use the * key to get the p, + and w chars. <br />'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with. <br /><br />#pw+1234567890+1# for Provider-Lock status <br />#pw+1234567890+2# for Network-Lock status <br />#pw+1234567890+3# for Country-Lock status <br />#pw+1234567890+4# for SimCard-Lock status <br /><br /># = DOUBLE-CROSS <br />W = PRESS "*" THREE TIMES <br />P = PRESS "*" FOUR TIMES <br />+ = PRESS "*" TWO TIMES <br />MASTERCODE = 1234567890 <br />Y = NUMBER 1 TO 4 <br /><br />(master code) is a 10 digit code, based on the phones IMEI number. <br /><br />Eg. To remove restriction on lock 1 type following code: <br />#pw+(master code)+1# <br />If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code) <br />eg. To check if phone if restricted on lock 1 type the following code: <br />#pw+1234567890+1# <br /><br />Bypass the SP lock With a Nokia 16xx/21xx/31xx/51xx/81xx <br /><br />1. Insert SIM card of different provider. <br />2. Turn on the phone and press the UP VOLUME key for 3 sec. <br />Then release it and the phone says PIN CODE? <br />3. Press the "C" key. <br />4. Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#<br /><span></span>
on Dec 19, 2010 | Cell Phones
Tip
How to unlock nokia mobile
nokia unlocking steps
  1. Find the Serial number of the nokia phone, also known as your IMEI number. This IMEI number help you to find nokia unlock codes for various nokia models. This can be done by either removing the back of your cell phone and looking underneath the battery, or simply by typing in *#06# into your cell phone. It should be something like: 010072321539976/07961780836
  1. power the phone on.
  2. You will see a message "Insert SIM Card". Enter all of the characters you see in your code, including the # symbols. To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w' press the * key 4 times. Disregard any spaces in the code.
#PW+1234567890+1# = GIVES PROVIDER-LOCK STATUS
#PW+1234567890+2# = GIVES NETWORK-LOCK STATUS
#PW+1234567890+3# = GIVES COUNTRY-LOCK STATUS
#PW+1234567890+4# = GIVES SIM-CARD-LOCK STATUS
I suggest to read this blog(http://mobile-cellphones.blogspot.com/) before doing this nokia unlocking. It guide you steps by steps how to unlock mobile phone.
on Dec 09, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
The master code is nt working plsss help..:((((
*#06# for checking the IMEI (International Mobile Equipment Identity) for Nokia 7210 To view Week and Year of manufacture enter *#3283# [*# D A T E #]
To view the software version on Nokia 7210 enter *#170602112302# or *#9999#
All Nokia phones (Nokia 7210 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1)
The main code used in Nokia 7210 phones is :
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
#pw+1234567890+1#
(please help me as I helped you)
Oct 15, 2010 | Nokia 7210
Security code for Nokia 2100
The main code used in Nokia phones is :
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
#pw+1234567890+1#
The phone now says: PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option !
Dec 17, 2008 | Nokia 2100 Cellular Phone
Key pad lock and unlock Nokia 1200
My local Nokia Care Center provided the easy answer (which does not appear in the
owner's manual):
In the Menu, go to Settings, then select Phone settings, and activate "Keyguard Settings," and "Automatic." That done, you must select the time interval until the keypad self-locks. To unlock,
touch the "select" key (upper left key) and * (lower left). That combination also will relock the keypad.
Sep 11, 2008 | Cell Phones
Master unlock code nokia6265i
These codes will work on most Nokia Mobile Phones to activate/deactivate advanced hidden functions that you can’t change through the phone menuOne useful function that all Nokia’s I’ve owned have is “Cell Info Display” which can usually be found in the phones “Display settings” (eg: in a Nokia 1600) or “Phone Settings” (eg: in a Nokia 3315)If your network supports it, when “Cell Info Display” is enabled, it will display the name of the base station your mobile is currently connected to on the screen eg: when i’m walking around the city it says “Sydney CBD” and when i’m at home it displays the name of my suburb.
Note:
To display “p” press “*” three times within one second, To display “w” press “*” four times within one second, To display “+” press twice “*” within less than a second
Code Function
*3370# / #3370# Activate / Deactivate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
*#4720# / *#4720# Activate / Deactivate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#7220# / *#7230# Enable / Disable PCCCPH support (faster GPRS)
#pw+1234567890+1# Provider Lock Status. (use the “*” button to obtain the “p,w” and “+” symbols)
#pw+1234567890+2# Network Lock Status. (use the “*” button to obtain the “p,w” and “+” symbols)
#pw+1234567890+3# Country Lock Status. (use the “*” button to obtain the “p,w” and “+” symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the “*” button to obtain the “p,w” and “+” symbols)
12345 This is the default security code
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999# Phones software version if *#0000# does not work
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
*#67705646# Removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature “SIM Clock Stop Allowed”, it means you will get the best standby time possible
press and hold # Lets you switch between lines
*#7760# Manufacturers code
*#7780# Restore factory settings
*#8110# Software version for the nokia 8110
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
Instructions to Network Unlock Your Mobile
Once you have bought or found a network unlock code for your phone, this Network unlocking guide will give you step by step instructions to enter it into your Code error – appears if the unlock password entered is incorrect. You need to go through the whole process again, ensuring you enter the correct 10-digit code.SIM was not restricted – appears if the handset has not been locked to a network. You should be able to use any SIM card in this handset.Not allowed - If the syntax while entering the unlock password is incorrect, nothing happens. If you have tried to unlock the phone 5 times with an incorrect password any further attempts to unlock the phone will generate this message. The phone will need to be electronically unlocked at a Nokia service centre.
Jun 20, 2008 | Cell Phones
Master code for all nokia 3110
Nokia Unlock Codes, Nokia Phone 3110 Secret Codes, Cell Phone Codes
Nokia 3110 Secrets
*#7780# Restores Factory Settings (Memory, language, counters are not included).
Press the following warranty code :
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it. The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) The main code used in Nokia phones is:
This code is able to check, activate or remove SIM card restriction (SP-lock).
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit code, based on the phones IMEI number.
#pw+1234567890+1#
NOTE : These codes could be used with care. A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIM locked to one provider you can bypass the SP lock like this:
3: Press the "C" key.
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed
Jun 10, 2008 | Nokia 3110 Cellular Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
