Question about RCA 27V520T 27" TV
Volumn not working
I have a RCA 27v520t. Connected to it is a TIVO and Cable box. This morning I was using the TIVO and hit the TV Mute to quiet the annoying TIVO beeps. (as I have done before). WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. Any suggestions would be appreciated David36078
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Posted on Sep 22, 2007
My volumn doesn't work when using the HDMI cable
Your TV and the cable box may not be compatible via HDMI or the digital audio format of the cable box is not set to PCM (contact your cable provider for information on how to change this on your cable box... too many models to speculate). The easiest solution is to use the component connections on the box and the TV (5 wire - Green, Blue, Red, White, Red). This will give you HD and eliminate to question of compatibility. I hope this was helpful, best wishes.
Apr 22, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My cable company just went digital. I have a TIVO
you will have to hook the tivo to the cable box and reconfiger, you will have to hook up the ir eye from the tivo to the box so thay can talk. the newist tivo is realy cool it take a cable card and can record muilt chanels but your old one when configured with the cable box will only record one chanel at a time and you wont be able to watch another channel wile its recording
Apr 15, 2010 | Vizio L32 32 in. LCD HDTV
I need code for RCA TV for Tivo remote
Go to http://support.tivo.com/app/answers/detail/a_id/294/kw/code%20search/c/105/r_id/100041 and under Programming TV Power, Volume and Mute, click on "show the steps".
Follow the instructions given.
The RCA remote codes are 0163, 0001, 0004, 0006, 0011, 0029, 0030, 0057, 0071, 0133, 0145, 0106, 0171, 0231, 0232, and 2210.
Try each of these codes one at a time (as per instructions) until you find one that works.
This link also gives instructions on what to do if none of the above codes work.
If this helps, please give a rating!
Oct 09, 2009 | Tivo Series2 TCD649080 Video Recorder
My zenith vcr recorder is recording blank but not my tv show and I don't know why. I have it plugged in to my tv - I have cox cable and a tivo box. My cable box runs ino my tivo and then to my tv. My vcr...
It seems to me that you have only got one set of RCA Cablec between the TV and VCR ( from VCR Video out to TV Video In), as such the VCR only works in playback mode, you need a second set of RCA cables (from TV Video Out to VCR Video In) then select the appropriate input (Video) for the VCR. make sure to follow the colour coding on the RCA plug / socket arrangement
Jun 18, 2009 | Zenith VR4206HF VHS VCR
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
TiVo installation
Since the Series2 doesn't do HD, you don't need any fancy connections, and it's pretty simple to hook up.
1) Disconnect the cable that's connecting your cable box to your TV, from the TV end.
2) Connect the end that *was* connected to your TV, to the "input" on the Tivo.
3) Get another piece of the same cable (coaxial cable), and connect the output of the Tivo to the input on your TV.
That's it.
You may just need to go to Best Buy and get a piece of coaxial cable to connect the Tivo to the TV.
If you need further help, let me know.
Dec 15, 2008 | Tivo Series2 Digital Video Recorder...
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Non-HDMI Tivo connection
The solution I use is S-Video from cable box to TIVO, and from TIVO to TV. That gets you the highest quality signal that the TIVO can handle. To watch true HD signal, switch TV from S-Video input to Hi-Def input and tune to HD channel. I have an HD cable box connected to both outputs, your situation may be different.
Feel free to ask for more help.
Jeepster77
Jan 16, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tivo Programing
You either don't have it hooked up right w/ the source video cables connected or if you've changed setups from one tv to another (different cable box or input) you need to go through guided setup again, but first check your cables, ensure they are going to the inputs (rca or coax) and not going to the outputs.
Dec 03, 2007 | Tivo Series 2 80-Hours Video Recorder
Televison & Video Logo
205 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
