Toshiba e-studio161 Developer
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]“000””000” will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] “000””000” will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY’S PAPER SIZE SETTING
Follow these steps to change a tray’s paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
