Question about Sanyo PLC-XP100L Projector
After connecting power cable to Sanyo xp 110l it does not shows any power light or any indicator led is lighted should i try to again using remote or projector is dead ? few hours before it was working fine
3 Suggested Answers
  • 3 Answers
SOURCE: Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
Posted on Aug 23, 2008
robgarcom
SOURCE: Sanyo PLC-XU58 projector completly dead
I had the same problem and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure.
Posted on Oct 12, 2008
I have a Sanyo PDG DXT10L, he won't turn on, all leds flashing orange
This flashing light usually indicates that the cable is connected and power is going to the system. Remove the lens cap and press the on/standby button. try resetting if this does not work.
May 02, 2011 | Sanyo PDG-DXT10L Projector
I need the code to my sanyo tv
Hello
According ro RCA Codes for sanyo are detailed as
Code 004 for sanyo tv Code 048 for Sanyo TV Code 049 for Sanyo TV Code 073 for Sanyo TV Code 080 for Sanyo TV Code 107 for Sanyo TV Code 162 for Sanyo TV Code 169 for Sanyo TV Code 180 for Sanyo TV Code 196 for Sanyo TV
Just check with these codes according to the proceedings.
1. Manually turn on the TV.
2. Locate the enclosed TV Code List. Find
your brand of TV.
Note: If your brand is not listed, use one
of the Code Search methods to program
this remote control. (See section on
Code Search.)
3. Press and hold the CODE SEARCH key
until the indicator light illuminates.
Then release the CODE SEARCH key.
4. Press and release the TV key. The indicator
light blinks and then remains lit.
5. Use the number keys to enter the first
code listed for your brand. After you
enter a valid three-digit code, the
indicator light turns off.
Note: If you enter an invalid code, the
LED flashes rapidly for two seconds.
Start over at step 3.
6. Aim the remote at your TV and press
the ON•OFF key. If your TV turns off,
you have found the correct code.
7. Enter the code in the box provided on
this page for future reference.
8. If your TV doesn't turn off, repeat steps
3-6 above, entering the next code for
your brand.
Manual Code Search
1. Manually turn on the component you
want the remote to operate.
2. Press and hold the CODE SEARCH key
3. Press and release the component key
that corresponds to the component you
want the remote to operate (TV, VCR,
DVD, DBS•SAT, CABLE, AUDIO). The
indicator light blinks once and then
remains lit.
4. Aim the remote at the component. Press
the ON•OFF key continuously until the
component turns off.
Important: Because there are so many
codes, you may have to press the
ON•OFF key many times-possibly up
to 200 times.
5. When the component turns off, press
the ENTER key to store the code.
6. Use the Code Retrieval section on the
next page to identify the code for your
component for future reference.
OK
Feb 15, 2011 | RCA RCU600M Remote Control
GE 5-Device Learning Remote i need the code for my sanyo tv so i can reprogram it
You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thank You
Oct 23, 2010 | Televison & Video
I need a code for a rca and a coby remote controle
Sanyo. 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
1. Manually turn on the component you want the remote to control
(TV, VCR, DVD, satellite receiver or cable box).
2. Press and hold the component key (TV, VCR·DVD, SAT·CBL) you
wish to program. The LED indicator light turns on and remains on. If you release the component key any time during the Direct Code Entry
procedure, the LED indicator light blinks four times, and the process
is exited.
3. While holding down the component key, enter the four-digit code that corresponds to your component’s brand. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key.If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry. If you enter a code number that
is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2 and try the next code listed.
Dec 01, 2009 | RCA Universal Remote Control
Need code for cable box(motorola)and tv(rca) can
The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with turning the TV on, then follow the steps substituting the TV button for the CABLE or SAT button.
I hope that helps.
Nov 16, 2009 | Innovage Jumbo Remote Control
Need code for sanyo tv
The codes for your Jumbo Universal Remote to control a Sanyo television are 004, 013, 049, 108, 110, 180, and 209.
  1. Turn on your TV.
  4. Enter the first 3-digit code from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
I hope that helps.
Sep 20, 2009 | Innovage Jumbo Remote Control
Codes for a sanyo tv for my innovage jumbo universal remote
  1. Turn on your TV.
I hope that helps.
Jul 31, 2009 | Innovage Jumbo Remote Control
Sanyo DP42746 - Screen went black and no sound. Power light on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 16, 2009 | Sanyo DP42746 42 in. Plasma Television
My Compaq wont turn on!
That flashing usually indicates a battery/power issue. Could the battery be dead? And/Or the power cable? Normally the power cable has a "brick" in the middle, and that connection could be loose. In many cases that brick has a led light when it is plugged it. Does your machine have that light and if so, is it lit? Does the "charging" or "AC power" light go on when it's connected via the power cable? Lastly, try removing the battery entirely, and using just the power cable, to make sure the battery is not causing the problem.
Jan 28, 2008 | Microsoft Windows XP Professional With...
Sanyo PLC-XP100L Projector Logo
32 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
