Chicago Pneumatic Cp-864 6" Air Sander Logo
George capuano Posted on Apr 20, 2013
Air sander will not turn off Chicago pneumatic cp 864
5 Related Answers
John Trevino
  • 1420 Answers
  • Posted on Dec 10, 2008
SOURCE: picture of assebly for chicago pneumatic demolition tools
Parts / Diagram here http://www.toolsrenewed.com/AirToolPrints/CP/CP-1230%20Breaker.pdf
You might post again describing the problem that you are having with the hammer. Enjoy
Anonymous
  • 3 Answers
  • Posted on May 24, 2009
SOURCE: DA SANDER RPMS SLOWED
get some air tool oil and oil it lol, if that will not speed it back up you may have to take it apart and clean it but the oil should do the trick. Do NOT use wd40, etc. use air tool oil
Anonymous
  • 141 Answers
  • Posted on Sep 09, 2009
SOURCE: i need parts breakdown lists for jack hammer
Follow these links and you can get the breakdowns for both:
http://www.crowdersupply.com/116.htm
http://www.crowdersupply.com/117.htm
Crowder Supply also has a lot of other breakdowns you can look through.
Anonymous
  • 10515 Answers
  • Posted on Mar 17, 2010
SOURCE: my cp 864 dual action sander needs part
You could buy it from :-
http://www.toolsource.com/valve-kf124233-p-74658.html
Click on Add to Cart and then Purchase the Amount.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Anonymous
  • 112 Answers
  • Posted on Jul 21, 2010
SOURCE: Manual for Chicago Pneumatic CP 7440
these things are pretty simple......make sure you oil every time you use it....it has 4 setting of torque 1 being the least power thru to 4 being strong....then it forward...clockwise or reverse anticlockwise...thats it,push the slide button from the front and then from the back of unit.
Chicago Pneumatic Compressors. Model: HX2T-100NP. I NEED CP HX2T -100NP MANUALS please?
Question edited for clarity. Always add full 'maker model (what it is)'.
Question moved from Office Equipment.
https://www.google.com/search?q=CP+HX2T+-100NP+manual
contact maker direct.
https://compressors.cp.com/
Manual for chicago air impact 1/2 or other.
If you have a newer of current tool you can go to CP.COM.
If it's an older tool try this link:
Chicago Pneumatic Service Repair Parts OEM Pro Am Tools
HOW DOES IT WORK WITH NO CORD???
If the product your have this listed under is correct then you need to hook up an air hose to this sander to make it work...it works on compressed air...
heatman101
1helpful
2answers
My cp 864 dual action sander needs part #KF-124233. Is it available?
Hope i helped you.
Sander stalling
Try to increase the psi to 125,if possible.also clean the air tool out with wd 40 and or auto trans.fluid.Try this and put it in the end of gun where the air goes in at.
2answers
I need to find parts for my old Chicago Pneumatic impact wrench
You may be able to find your parts online but you will probably pay a lot more than you need to. Your best bet is to call or go to a service center that deals with CP. There are 3 different anvils for that particular model so you will have to get the right part number. You can get information by emailing or calling CP for the nearest service center to you.
1helpful
Picture of assebly for chicago pneumatic demolition tools
Top Chicago Pneumatic Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Chicago Pneumatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
