Question about Alpine HCE-C157D
Need rca converter box for alpine hce-c157d - Alpine HCE-C157D
I need help hooking up a rca converter box in a Lincoln town car carter with the alpine stereo system
Is the converter powered or passive? Each RCA (red or white) connection represents a + and - speaker wire for one speaker or channel. So assuming you already have the amplifier you'll cut the speaker wire coming from the head unit. From the head unit speaker wires will attach to the input or hi-level connection on the converter. The other half of the wiring goes to the speakers in the doors. Those will go to the amplifier which is or should be fed by the RCA's on the hi-level converter box.
Passive coverters don't require 12v power but active ones will need 12v input from a remote signal such as from ignition circuit or a power antenna to turn the unit off and on so your battery isn't drained with the car off.
Feb 28, 2017 | Alpine Car Audio & Video
I have a RCA converter box model STB7766c and have a RCA RCRN03BR remote, and I need the codes for the converter box
ONCE AGAIN, A SIMPLE GOOGLE SEARCH!
Second thing on the google list for RCRN03BR
Remote Code Finder
RCA 52325, 52454 for digital TV converter box.
Sep 03, 2016 | RCA Televison & Video
How you make the camera work for front view on alpine INEw927hd? How do you connect the camera that came with the unit?
you must buy one of these camera and install one in the front of vehicle and one in the back to inew927hd. read the following (With front or rear camera installation, the screen on the INE-W927HD will automatically switch to your front or rear camera view. For the front of the vehicle connect the HCE-C212F or HCE-C200F and for the rear, an HCE-C210RD, HCE-C200R, HCE-C117D, HCE-C115, or HCE-C104. These camera systems will work directly with the INE-W927HD for a clean and easy install. For camera multi-view control directly from the INE-W927HD, the HCE-C210RD for the rear and HCE-C212F for the front can be used.) camera setuppage1 camera setup page 2 , camera setup page 3 depending on the camera installed certain cameras allow different displays on the video screen ... any more questions email me at radiorepair@windowtintingin239.com
Oct 27, 2013 | Alpine Car Audio & Video
Want to connect ipod, how can i do that
Its on the back of the radio. Here is the link for the part you need to convert to rca's so you can plug in a ipod.
http://cgi.ebay.com/Alpine-Ai-Net-RCA-Aux-Input-Cable-KCA-121B-for-IPOD-A1_W0QQitemZ110466314443QQcmdZViewItemQQptZOther_MP3_Player_Accessories?hash=item19b84e30cb
Apr 08, 2010 | Alpine CDA-7897 CD Player
I have a alpine amp i need to install in to my f150 truck with a factory radio
The easiest way to accomplish this is to get a kit from your nearby stereo shop that will convert your stereo signal from your factory unit to a pair of rca outputs .You can get them from walmart if you feel up to the task of wiring it up. You will still need to get an amp wiring kit as well from there its just a matter of running power ground and rca cords also a remote lead to turn the amp on and off-you can do that from the fuse box easy enough.-after that just run your speaker wires from the amp to the speakers and your in business.hope that helps
Feb 14, 2010 | Alpine MRP-M350 Car Audio Amplifier
Need to wire alpine amp to factory ford radio
use one of these in parrallel on the speaker output, and connect the RCA-RCA on the amp, should work fine
http://cgi.ebay.co.uk/Speaker-to-RCA-Line-Level-Converter-Adaptor-Pre-outs_W0QQitemZ370214078716QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Amplifiers_PP?hash=item56327a88fc
How can I get my ipod to work on the Alpine CDA-7892?
Ai-NET/RCA Interface cable (KCA-121B)
Converts the changer port to RCAs... then an RCA to female 3.5mm female adapter.
Or an FM Modulator.
Thanks for using FixYa - a 4 thumbs rating is appreciated for answering your FREE question.
Dec 26, 2009 | Alpine CDA-7892 CD Player
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Alpine CDM-9821 CD Player
an easy way would b 4 u 2 gent an fm tramsmitter thats the cheap route if its not on output 4 an ipod connection im pretty sure u can hook up ur amp the only wires that need 2 com from th in-das is a remote and ur rca the remote wire should b blue n u can get a headphone converter with rca ends but i doubt ur ipod will play out of ur amp.... let me know if this helps
Jun 23, 2009 | Alpine CDM-9821 CD Player
Alpine HCE-C157D Logo
62 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
