Question about Toshiba Satellite S855D-S5256 : 2.3GHz A10 Series 15.6in display
Wireless communicatin switch for toshiba laptop s855d
Where do I find the switch because I cannot get the wireless to work. I need to enter the wireless network key
  • 56 Answers
SOURCE: Toshiba SPM30 Wireless
check device manager to see if appears under netwok adapters if yes look for switch
Posted on Mar 20, 2008
furlough5
  • 28 Answers
SOURCE: wireless network
Hi xiomaravlz. To turn on the wireless for your Toshiba Satellite, there is a switch on the very front of the laptop. Up where the headphone jack is. When you turn it on, you should see a light beside it.
Hope this helps!
Posted on Aug 27, 2009
anandsharad
  • 137 Answers
SOURCE: I need the wireless network driver for a toshiba
you cn find this on this weblink. its the Toshiba Tecra Sound driver. or what else you can do in the same weblink, you may find the option to scan your computer for drivers. it will scan and install by itself.
i am sure this is resolve your computer's sound.
Posted on Sep 24, 2009
  • 19 Answers
SOURCE: The wireless switch on my toshiba satellite u400
Is more than likely the wireless LAN card has gone faulty.
If the laptop is no longer under warranty, you will probably find its cheaper to plug in a USB Wireless Dongle.
Not ideal I know but it would be cheaper - and quicker.
Posted on Mar 30, 2010
picaflooor
  • 99 Answers
SOURCE: Wireless connection
you can try to totally disable it, by doing right click of the mouse in top of the broadcasting wireless icon. once is disabled, you can go by START / CONNECT TO / WIRELESS CONNECTION and try again. that should work.
Posted on Apr 23, 2010
Cpu fan
The fan may be fine, (or not If it's making a rough noise,) Could be packed with dust or hair, or I've seen a label come loose and stop it turning. Either way you'll need to take the LT apart. Here is a guide which will hep you.. Follow step by step.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-S855-S855D-S850-S850D/Toshiba-Satellite-S855D-disassembly-1.htm
You'll need to order a replacement.. Just Google your model number and the words CPU fan, you ought to get plently of options.
Nov 09, 2013 | Toshiba Satellite S855-S5377 Notebook...
Tip
How to configure the wireless connection ?
Configuring the Wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
on Jan 22, 2010 | Computers & Internet
I hit FN +8 on my Toshiba Qosmio F45, but the wireless light will not go on, what should i do
Try reinstalling the wireless driver.
You can download the wireless and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Mar 21, 2013 | Toshiba Computers & Internet
I have toshiba l500 i changed windows vista to windows 7 now its wireless not working
First thing to do is to Go to the Toshiba Support site, ... navigate to the driver support page for your specific laptop model, ... then download and install the WI-FI drivers for your wireless card that are Windows 7 compatible. That should get your wireless working, ... UNLESS your wireless feature has been shut off in the BIOS. If that's the case, you'll need to enter the BIOS when booting the laptop and turn the wireless feature on.
While your downloading the Wi-FI drivers from the Toshiba site, you should also download the latest BIOS update IF it's a newer build than the one surrently installed in your laptop. Also download and install the motherboard chipset.
I'm pretty sure your problem should be taken care of if you follow those steps.
disaksen
Jan 12, 2011 | Computers & Internet
Wireless on toshiba tecra l2 quit working for no apparent reason. tried everything but installing new drivers. any ideas besides new drivers?
Try installing the latest wireless driver.
You can download any orall the Windows XP or Vista device drivers for your model laptop from theToshiba WEB site from their download page. Make sure you enter the model ofyour laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Dec 27, 2010 | Toshiba Tecra L2 PTL2XU001001 Notebook
My toshiba wireless does not work. It does not show any wireless service. I have two computers and the other computer works. I have reinstalled the entire hard drive and updated the software. It still...
What model of Toshiba laptop do you have?
What operating system? XP, Vista or 7?
Make sure the wireless switch on the side of your laptop is in the on position.
Make sure there's a wireless icon in the lower right corner of your screen, and it doesn't have a red X through it. (If it does, your wireless is turned off or otherwise not connected to anything.)
Look in the Device Manager and look under Network Adapters. Make sure there's a wireless network adapter installed, and it doesn't have any yellow question marks or anything on it.
Wireless can also be enabled or disabled in your system setup (before Windows starts). Power on your computer from scratch, and when you see a "Press F2 to enter setup" prompt or something similar, hit that button and enter the system setup. Look through the menus for device configurations. In there you can turn on or off certain things.
Good luck. I hope this gives you something to go on. Let me know if you need any more help!
Mar 12, 2010 | Computers & Internet
My problem is that i cant figure out why i cant get internet on my D-Link router and i cant figure out how to scan it?
Scan for network will not work because of 2 reason
some times the Software utility causes the Problems
start - run - msconfig .. stop the services
but check the following ..
Check the Following
Windows XP
2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field onpaper, and store it in a safe place. THIS IS YOUR WEP KEY, it will beneeded later on.
Jan 24, 2010 | Computers & Internet
Toshiba Satellite S855D-S5256 : 2.3GHz A10 Series 15.6in display Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
