Question about Neff U1661 Double circotherm super Electric Oven
My Neff U1661 oven is displaying error code 444?
The light and fan are working but there is no heat. We have replaced the element.
barkencoa
  • 3463 Answers
SOURCE: Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
Posted on Nov 21, 2008
2coolrick
  • 560 Answers
SOURCE: Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Posted on Jun 05, 2010
barkencoa
  • 3463 Answers
SOURCE: Neff single oven won't heat
If the fan is working o/k, then the element is faulty, or it is not getting power to it, you need to test with a meter for a supply to it.
Posted on Sep 23, 2010
  • 52 Answers
SOURCE: I have changed the element on a neff u1661 main
Is the loose cable on the element , if yes ISOLATE THE APPLIANCE BEFORE REMOVING PANELS
Usually they are spade terminals remove the affending connection, with a pair of pliers carefully press the terminal into itself, not too hard, it will be hard to put back on the element, move the terminal from side to side and ease on with continuous pressure. while you have the back off if you have a multimeter switch the mains back on, use extreme caution select A/C voltage above 250 volts, switch on the oven the fan will start to blow measure across the terminals, if you get a reading of 230 volts A/c the element should start to heat up. If no voltage, send me a reply.
Hope this has been helpful
John
Posted on May 19, 2011
SOURCE: how to replace knobs on u1661 oven
Just pull them off and replace. Its that simple.
Posted on Oct 26, 2012
Tip
Common heating faults with Neff U1661 Double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1661 Double circotherm super...
Top oven temp display shows 4444
Control panel needs to be replaced. It may also be an error code for the repairman.
Jul 22, 2012 | Neff U1661 Double circotherm super...
I have changed the element on a neff u1661 main oven but still doesn't heat up. I noticed that one cable is loose possibly the earth?.the top oven and light and clock all work. Any suggestions please.
John
May 19, 2011 | Neff U1661 Double circotherm super...
Main oven does not get hot the fan work and all the lights come on but none of the ements heat up
You need to replace the oven element located at the rear of the oven compartment behind a removeable cover.
Nov 22, 2010 | Neff U1661 Double circotherm super...
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Hi.
Good luck
Nov 21, 2008 | Neff U1661 Double circotherm super...
TOC
hi there if your toc is at fault you will have no oven function at all ie. fan, light, and timer display. i would first check your timer is not set to auto and is also got the time set, failing that your thermostat may be at fault.
May 22, 2008 | Neff U1661 Double circotherm super...
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
No heat in the main oven
Hi
We had the same problem - turned out to be the fan oven element - simple to fit - remove the back plate around the fan (6 screws) to expose the element. Remove screws securing element and disconnect wires (mark wires before removing) Our replacement was £40, but take the original as there are quite a few variants - you will also need the full ENR number (on side of housing) However, be aware that if this does not work, the thermostat may also have blown with the element. We were lucky as replacing the elelment fixed the problem.
Nov 26, 2007 | Neff U1661 Double circotherm super...
Neff U1661 Double circotherm super Electric Oven Logo
168 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
