Question about Garden
What are the valve clearances for a Honda HRU19D lawn mower
cxbxr_3
  • 11 Answers
SOURCE: Honda Self-Propelled Lawn Mower leaking oil?
It is toast you fried the crank/connecting rod, by running it low on oil.
Its hard to say what caused the oil leak, but now it is ruined.
Posted on Aug 12, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
  • 18 Answers
SOURCE: Honda HR 17 lawn mower dies after it starts
01 Fuel tank cap? Loosen it to see if it is plugged.
02 Possible fuel line obstruction? Disconnect at carb to make sure there is adequate fuel flow.
Posted on Apr 20, 2010
Valve clearance Briggs model# 331877 1371b1
Danny, I set lash at .004" / intake and exhaust clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
briggs and stratton 21HP backfires like cannon
YTS3000 Craftsman model 917 289213 valve gap setting 331877 1371 B1 Briggs...
Lawn Mower Repair Valve Adjustment
Jul 08, 2016 | Garden
How do i adjust the valve clearance
Have you checked the blade for balance? Bad gas?
Feb 10, 2016 | Honda HRX217VKA Lawnmower
On the crank gear an cam gear do the dots meet when its TDC an both values are open on a 17.5hp mtd OHC lawn mower ser#1a276b30280. Mod#13bn771g729.
both valves are never open at same time!! the 2 dots should meet up at tdcbth valves closed, valve clearances should be approx .006-.008 inch
Mar 03, 2015 | Mtd Garden
What is the tappet clearance on a Honda HRU196 push mower?
You should be able to fnd this info on Partstree.com
General for small engines is .015 inlet and .018 exhaust. Bit this is on a 4 hp engine.
Feb 18, 2015 | Honda Garden
How do i change the mower blades on my honda hru19d
Check this site for changing mower blades. Seems straight forward:
HOW TO CHANGE LAWN MOWER BLADES
Feb 11, 2015 | Honda Garden
Set valve clearance on 21hp briggs and statton
Valve clearances are set by either tappet screws in the lifters or on a lot of small engines, clearances must be set by either cutting out valve seats with a special cutter tool (to DECREASE clearances) or grinding the end of the valve (to INCREASE clearances) and generally are from .008-.010 on intake valves and .010-.012 on exhaust valves. Check engine specs to insure proper clearances.
Sep 24, 2014 | Garden
What is the valve adjustment spec on a brigs @ sttraton
There is no adjustment. The clearance is pre-set by the valve length and tappet length. If the valve seat is worn the clearance becomes non-existant. .020-0.30 clearance for both intake & exhaust will work okay.
Aug 21, 2014 | Garden
GXV 160 Honda, spark plug very sooty, when pulling to start it fires back through carb, have reset valve clearances which were near good enough but wondered about timing or poorly seating valves
you need to do a cylinder leak down test. That will tell you if it is a valve, which one or if it is rings. Try a compression test too. 5 pulls should be 160 to 190 ish. If all that is ok check the carb to see why it is causing a rich running scenario
Jan 10, 2013 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
Honda lawn moweri would like valve clearances for 191 cm engine
9/1000 on intake and 11/1000 on exhaust
Dec 21, 2010 | Garden
I have a Tecumseh 12.5 hp vertical ohv engine Model OV358EA (OHV110-135) The rocker has come loose, pushrod jumped out and stopped engine. I need to reset valve clearances, I have no manual to give me...
My 13.5hp ov358ea is .004 both valves. Would like to know model of your engine. I want to replace the non-adjustable carburetor of my 13.5hp ov358ea with an adjustable carburetor.
Retired Airline Mechanic
Jun 26, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
