Question about LG LHT854 Theater System
Upgrade software lh-tk3602 - LG LHT854 Theater System
What is the difference between GLC-LH-SM and GLC-LH-SMD?
They are 1000BASE-LX/LH SFP for Both Multimode and Single-Mode Fibers, compatible with the IEEE 802.3z 1000BASE-LX standard, operates on standard single-mode fiber-optic link spans of up to 10 km and up to 550 m on any multimode fibers.
If one switch supports Cisco SFP GLC-LH-SM, then it can also support Cisco SFP GLC-LH-SMD.
The difference between GLC-LH-SM and SFP GLC-LH-SMD is the letter "D".
What does "D" mean?
"D" of GLC-LH-SMD transceiver has additional support for Digital Optical Monitoring (DOM) capability.
What is Digital Optical Monitoring(DOM)?
This feature gives the end user the ability to monitor real-time parameters of the SFP, such as optical output power, optical input power, temperature, laser bias current, and transceiver supply voltage.
The comparison between GLC-LH-SMD and GLC-LH-SM.
Related Source:
https://supportforums.cisco.com/document/75181/digital-optical-monitoring-dom
GLC LH SMD Overview
GLC LH SM LC Overview
Aug 18, 2017 | The Computers & Internet
I am still waiting for an answer regarding my question, that I asked earlier. I remembered his name, it was IAN
to get a short cut to desk top click on the start icon ( little flag world in bottom lh corner )
click on all programs , scroll down until you get the program you want on desktop, click and drag it across to the desk top and let it go
that is your shortcut on desktop
do that for all programs you want on desktop
Jan 04, 2016 | Software FX Studio FX Premium Subscription...
How do I upgrade my LG LH 20 lcd tv firmware
As far as I can see on the support page, here: Product Support
there is no firmware upgrade. An upgrade is only made, when several people have a issue with there device, and it can be solved by upgrading the firmware. Ir is NO SOLUTION for real defects.
You even can't upgrade if the device is not working correct.
It needs to run a short program, put is a small part of the RAM, and during the upgrade it can't lose power, because the little program has to flash (put new software in) the electrical erasable memory.
When something goes wrong during the update, nothing works and you need to visit a service centre to put things right.
As long as your TV works fine, don't update. When LG really does have an update, they will email all registered owners and carefully explain how to do the upgrade.
To be sure about any updates, register your TV on the support site.
When you have a problem with the TV contact LG or a certified repair centre close to you.
It would not be wise to try to change something on your TV, as long as you are not 100% sure it would improve the TV.
Jan 18, 2015 | LG Televison & Video
LH-20A1h not reading at all and never really think i was given the correct software for the unit when desktop was built. Does say in my computer that it is working correctly!?
you dont need to install any third party software to have it read disks. uninstall that and give it a go, if it still doesnt work the laser may need cleaned
Feb 25, 2011 | Lite On LH-20A1H DVD RW Dual Layer Burner
Lite-on dvdrw LH-18A1P PROBLEM
insert correct cd rom comes only in 2situations
  1. if the software requires to start with the help of cd. try to start program with cd inserted in CD ROM
  2. software is pirated. if it is pirated then in the cd there must be folder named "crack" in it. copy all the files of crack in program files of software
  3. pls rate my solution
thankyou for using fixya
Feb 14, 2009 | Lite On LH-18A1P DVD RW Dual Layer Burner
Liteonit dvdrw Lh 20aip driver needed
http://club.cdfreaks.com/f44/liteon-lh-20aip-unable-read-220078/
In this web site you can download the driver software for your cd drive.
please try it and infrom.
May 06, 2008 | Computers & Internet
Lite-on DVD R/W combo LH-20A1L BLO5 Blank discs not recognized
Have you checked device manager to see if you have a yellow checkmark on your DVD./CD drives? if ok, sounds to me like the maker of the LH-20A1l BLO5 either needs to fix your problem or replace it. The Nero 7 should enable it to work correctly.
Feb 14, 2008 | Computers & Internet
My LITE-ON DVDRW LH-20A1H thinks its a cd burner???
It seems Lite-on Has a lot of Probs.In fact I had the same model on an SATA system.It would not burn dvd's or cd's.You can try updating your burning software,and reinstalling the drive through device manager.I actually ended up buying an LG burner....lo-and behold...it works without any problems.Good luck
Feb 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Won't burn picture image
http://www.liteonit.com/global/index.php?option=com_content&task=blogsection&id=9&Itemid=69
if you can copy an image ( alone- nothing else waste a disc here) as a data file it's the software - uninstall and re-install it--- if you cannot copy the image as a data file , it's the software in a different capacity and may you need firmware from the link - I would uninstall the device in device manager and then let wizard find it on a re-start
Jan 15, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
LG LH-D6230 DVD
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Susan
Jan 12, 2008 | LG LH-D6230 System
LG LHT854 Theater System Logo
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
