Question about Sharp Heating & Cooling
AY-X24LCJ H6 display
H6 on unit
It not working shows H6
They appear to be make specific
H6 OPERATION HALT DUE TO FAULTY POSITION DETECTION SENSOR
Tweet It means there is a fault in the temp sensor on the indoor unit that is working on with the cooling unit. It is a leak on the system. It also signifies that the air conditioner is low in charge. It is not getting the air conditioner to work in cooling. The cooling coil needs to be repaired. It could also be caused by not functioning controller board. See the vibration son the grill, glass, wooden and its plastic body.
Mar 18, 2016 | Heating & Cooling
Hi,I have a gree Airconditioner and its displaying H6 error,what should I do?
Google search your manufacturer make and model and the words error H6. You can find it in the search results, which will get you started.
Apr 01, 2015 | Heating & Cooling
Error code h6 my ac split electrulux?
H6 indoor unit fan stall.
Most likely a faulty fan motor but could be a faulty controller board. My money is on the fan motor which is a DC motor.
Apr 24, 2014 | Electrolux E23CS75SS Air Conditioner
Sagisag ng kromatiko
This doesn't seem to translate very well, but it seems like you might be wanting to switch your display to black and white or the reverse of that. This is typically done by adjusting the saturation to zero, and it will likely need to be done via adjustment of manufacturers display driver vs the Microsoft driver.
Ito ay hindi tila napaka-translate na rin, ngunit ito ay tila tulad ng sa iyo ay maaaring kinakapos upang ilipat ang iyong display sa itim at puti o ang reverse ng na. Ito ay karaniwang ginagawa sa pamamagitan ng pagsasaayos ang saturation sa zero, at ito ay malamang na kailangang ma-tapos na pag-aayos ng mga tagagawa display driver kumpara sa mga driver ng Microsoft.
Jun 09, 2013 | Computers & Internet
Fault code h6
Hi my washing machine ( a swan sw3010b ) keep draining the water and after a while it shows a foult IE. Can someone helps please
Nov 14, 2011 | Washing Machines
Videocon Split AC, Model VBS53 showing H6 Error. Please Help
h6 problem create a machine showing a display?
Jul 01, 2011 | Heating & Cooling
HI, KEYBOARD IS NOT WORKING PROPERLY, IF I PRESS H IT WRITES H6,IF I PRESS G IT DISPLAY G5,IF I PRESS H IT GIVES H6,IF I PRESS,\ IT OPENS MS HELP.AND ENTER BUTTON AND AEROWS KEYS ARE PERMANETLY NOT...
HI DEAR FRIEND
I know what problem having you
step1 right click to my computer
step2 click manage
step 3click device manager
step 4clic keyboard
step5 UN install the the keyboard driver
step 6install CORRECT keyboard DRIVER IN YOUR SYSTEM
OK
Apr 08, 2011 | Lenovo 3000 N200 T7100 1.8G 1GB 160GB...
DWD1210S/1210W
H6 is an error code with the heater - you will need to get a professional to look at it.
We have one of the machines and it has been trouble since day one. We will not be getting another.
Aug 17, 2008 | Washing Machines
Heating & Cooling Logo
15 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
