Question about Garmin zumo 550 GPS Receiver
Garmin 550 won't charge??!!
I use it in the car and works perfect. Connected it to my motorbike and won't charge at al?? Can anyone help as i have a long journey to Europe.
  • 1 more comment
  • lucas_spain Apr 03, 2009
    Exactly the same problem. Just bought the Zümo (500 Deluxe in my case). Just installed the mount. I'm getting electricity to the mount (I have tested the pins and they get current), but when mounted, the GPS doesn't charge. Any help?
  • bob_mcculloc Apr 04, 2009
    Zumo 550- works on the car mount. I have 10.2 V to ground on the car unit (3rd pin from left) and 9.85 V on the bike unit. I don't think this should make a difference. Any ideas?
  • armeav8r May 11, 2010
    Was it working ever? If so, then the mount has likely failed. Make sure power is connected and no fuse is blown. Check the source with a voltmeter.
5 Suggested Answers
marcelbakker
  • 174 Answers
SOURCE: Zumo 550
You'll have to select the europe map and deselect the usa map. Also you might have to change the locales. to do the first thing
tap wrench/tap map/tap about there you should see both maps, select the one you need and return to the wrench menu, select locales slect change all and walk through the menus (especialy the country!!!)
Posted on Jun 10, 2008
marcelbakker
  • 174 Answers
SOURCE: Garmin 550
Remove the battery an leave it out for about 10 minutes, then put the battery back, should startup....Oh yeah, if you have an sd card installed remove it.
Posted on Oct 27, 2008
  • 217 Answers
SOURCE: GARMIN NUVI 250. Was working fine,
remove the battery and reinsert it again and checkout.also press the reset button on the gps 2-3 times and check out.also try to charge the battery again.it could also happen if the battery goes faulty due to any reason.
Posted on Nov 30, 2008
  • 1514 Answers
SOURCE: I have a Garmin Nuvi
The solution is at http://www.fixya.com/support/r5555853-garmin_nuvi_2xx_shows_satnav_connected
Posted on Aug 13, 2010
I need the password of sniper elite reloaded
You can connect usb car charger the Garmin Zumo 550 to your motorbike with both an u-bolt mount or a clutch mount - which ever 1 you prefer. AmanStino Ultra Slim Lightweight Smart shell Stand Cover with Auto Wake...
Dec 31, 2016 | The Video Game Consoles & Games
Zumo 550
is the battery working fine.
Oct 21, 2008 | Garmin zumo 550 GPS Receiver
Zumo wont accept 12v charge from car or bike !
Did you drain the battery completly? Have you tried another battery yet? I've come across this issue once, seems the owner drained the battery completly. Leaving it hooked to the mains with the mains charger for almost a day did solve the issue. I'd try a new battery first.
Oct 19, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 AC adapter inop
Take the unit back for warranty service. If you are using the original adabtor it should work. Take note that the Garmin GPS's are designed to work only with original Garmin accessories.
Jerry G.
Jun 24, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 bluetooth pairnig problem
Have you connected the device to the computer and run webupdater? Mine showed up with a bluetooth firmware upgrade. Bluetooth works fine, however, lost the functionality of the phonebook after the update. Sometimes you win sometimes you loose
Mar 28, 2008 | Garmin zumo 550 GPS Receiver
No power
I had exactly the same problem with a 3 month old Zumo 550. Removed battery, waited a few minutes and replaced. System now poers on OK. All data on-board was retained.
Dec 22, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
97 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
