How to operate zanussi washing machine model zwq 5128 with norwegian language
  • 183 Answers
SOURCE: zanussi washing machine
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Posted on Sep 01, 2007
SOURCE: Zanussi IZ12 Pumps, then Pause LED is flashing.
hi i had the same fault, the machine would go onto pause after a couple of seconds.. after nearly a full strip down of the machine and checking the obvious i found there was carbon dust on the pcb which was causing tracking (the circuit board at the top of the machine). The pcb looked like it was burnt out, but after a quick dust down to remove the carbon and refitted back into the machine it worked fine. HTH
Posted on Jul 11, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Posted on Mar 14, 2010
heatman101
  • 43501 Answers
SOURCE: zanussi washing machine, conditioner doesn't empty
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 25, 2010
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
Feb 05, 2014 | Zanussi Washing Machines
Casio te-2000 language
Are your products still there? Normally you would lose all programming when the battery goes flat. There will be a code for your language in the intialisation section of your manual if it is not the standard language of the machine. Do you have a Norwegian manual.
Mar 15, 2013 | Casio Parts Cash Register PC Desktop
What is the EHT No OF videocon tv model no 5128 R
EHT Not work m.5128 r videocon old model
Aug 31, 2012 | Televison & Video
Eh0 error message during operation
need manual or need to know if washer starts and when it stops as this can identifie the problem
Aug 12, 2012 | Zanussi Washing Machines
Zanussi Washing machine ZWF1011W Operation Instructions
easiest solution is to visit zanussi website and download the operation manual. hope this helps
Feb 15, 2012 | Zanussi Washing Machines
How do i take front cover off washing machine
According to the model for removing the cover varies so here is the link for instruction.you can download your particular manual (model number)Zanussi - Washing Machine user manual, operation instructions.Good luck
Sep 28, 2011 | LG WM-1480FHD Front Load Washer
Hi. Bought a zanussi zwq 5120 easyiron in Hungary but there are no instructions in English. can u direct me to some? Lucy
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 27, 2011 | Zanussi Washing Machines
Hello i bought zanussi zwg1140M and i don't have english manual. How can get En. manual for this product? Thank
ZWG1140M is a washing machine, not a dishwasher. I have a user manual, but it's in Norwegian. Great washing machine, but the manual is hopeless!
Dec 20, 2010 | Zanussi Dishwashers
Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
Jul 17, 2009 | Siemens Washing Machines
Zanussi manuals
Click on 'washing machines' (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Apr 04, 2008 | Washing Machines
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
