Question about Motorola Mobility HS850 Consumer Headset
Pairing Motorola RAZR with the HS850
I have a razr and an HS850. I've had them paired together before and had no problems. It's been a while since I've used my HS850, and now they will not pair together. The phone says it can't find the device. Could this have anything to do with me no longer living in my cellular home area and am feeding off of another company's towers?
  • janine4u2hav Sep 05, 2008
    the phone saids i need a pin and wen i first got the bluetooth it was a certain pin and now that i have a new phone i entered the same pin and it saids its not pairing
  • Anonymous Feb 18, 2009
    I need the pairing instructions please
I need the paring instructions
Posted on Jan 23, 2008
    Problem Solver:
  • 13 Answers
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Posted on Aug 02, 2007
SOURCE:
NEED TO PAIR BLUETOOTH HS850 TO RAZOR V3
a With the headset’s boom closed, press and hold the Multifunction Button E until the headset indicator turns on (about 3seconds). The headset indicator turns on.
b Release the button, then open the headset boom. The headset indicator remains on.
2. Perform a device discovery from the phone. 3.select motorola hs850 and click pair 4 When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone. The device ID is now stored in the phone’s memory. Pairing is successful when the headset indicator flashes 10 times rapidly.
Feb 07, 2010 | Motorola Mobility RAZR V3
Pairing problems
Make sure your phone is blue tooth enabled ad that both are in pairing mode.
Jun 01, 2009 | Motorola Mobility HS850 Consumer Headset
Having problems pairing
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 12, 2009 | Motorola Mobility Universal Wireless...
I've lost my pairing code how can I get another on, or is there a
From the Motorola Website:
The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
This should work for you, but if it doesn't you'll to contact Motorola
Dec 05, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth Pairing with Motorola Razr
try to do this.. go to menu, settings, inittial set up, master clear, code (000000) the fone boots w8, then again go to menu, settings, initial set up, master reset, code (000000) fone boots again w8, .. then try to pair it again,.,, goodluck man!
Apr 28, 2008 | Motorola Mobility RAZR V3
Auto bluetooth problems with Motorola RAZR V3 cell
don't think so.
maybe while pairing up the new phone you have turned down the volume on the earpiece?
Nov 28, 2007 | Motorola Mobility RAZR V3
Pairing to bluetooth
The V3C cant pair with other phones.. I have to hold my bluetooth head set on top of my phone to get it to pair sometimes and make sure the headset is in pairing mode
Nov 09, 2007 | Motorola Mobility RAZR V3c Cellular Phone
H350
once it finds it it should ask for a passcode which is 0000or 1234
then it should store it.
If this does not work delete any devices of the same name in you phone and try pairing it again
Oct 11, 2007 | Motorola Mobility HS850 Consumer Headset
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Aug 14, 2007 | Motorola Mobility HS850 Consumer Headset
Can't connecto to headset again...
You are not alone in this endeavor. A lot of people have this problem. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
May 09, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
351 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
