Question about Kingston DataTraveler 101 G2
Microsoft window is requesting for disk formatting before open, what can we do?
  • 80 Answers
Re-insert your disk drive. This problem is also appear when your PC got virus. so try in another PC. The best idea is to FORMAT your drive. :)
Posted on Apr 20, 2013
Formatting from RAW to exFAT does not work. computer (Toshiba satellite W7) says unsuccessful
How to Format Hard Drive With Windows 8 eHow
Step 1:
Back up all data on the drive you want to format. Tap the "Search" icon on the Windows Start screen and type "format disk" in the Search field. Select "Create and Format Hard Disk Partitions." The Disk Management utility opens.
dff89d62-f4c0-4d6e-b10c-7cba410b4b66.pngSelect "Create and Format Hard Disk Partitions." (Image courtesy of Microsoft.)
Step 2:
Click the drive that you want to format. Note that in most cases "Disk 0" is the drive with the Windows operating system on it. If this is the disk you want to format, you should reinstall Windows instead.
2fe0d696-372b-421f-b49f-da062aabbeec.pngSelect the drive you want formatted. (Image courtesy of Microsoft.)
Sponsored Links
Step 3:
Click the "Action Menu," select "All Tasks," and then click "Delete Volume..." Double-check that you have the right drive selected. The selected drive is shaded with diagonal stripes.
531c247a-9340-42a7-a785-35c37c5490ba.pngSelect "Delete Volume." (Image courtesy of Microsoft.)
Step 4:
Click "Yes" at the warning that all data on the partition will be deleted. After a few seconds, the volume is deleted. The drive is now listed as unallocated in the Disk Management window.
d35f80cd-51ea-4d05-8911-98dcebc0c93d.pngDisk Management warns that all data on the partition will be lost. (Image courtesy of Microsoft.)
Step 1:
Select the drive you are formatting if it isn\'t already selected. Click the "Action" menu, then "All Tasks" and "New Simple Volume." The New Simple Volume Wizard opens. Note that if the disk is part of an array, advanced users will have additional options like creating a new spanned volume, striped volume, mirrored volume or RAID-5 volume.
94a33b72-44e6-461e-9920-f69735d78d0a.pngCreate a New Simple Volume (Image courtesy of Microsoft.)
Step 2:
Click the "Next" button in the New Simple Volume Wizard so you can specify your preferences.
2b3d2635-9525-4ee5-a259-c38b5ba47fbf.pngThe New Simple Volume Wizard opens. (Image courtesy of Microsoft.)
Step 3:
Specify how much space should be used in the new volume by entering a value in the text field. If you are creating only one volume or partition in the drive, this number should be the same as the maximum disk space displayed above. Click "Next."
40a2b160-a7c4-4669-9f7b-9acdec319786.pngSpecify the volume size. (Image courtesy of Microsoft.)
Step 4:
Select a drive letter that you would prefer the computer to use for this drive. If you don\'t want a letter assigned, click the "Do Not Assign a Drive Letter or Drive Path" option. Advanced users may also prefer to mount the drive in an empty NTFS folder. Click "Next."
a7adfda9-4b8d-4ac9-8d3f-f9ffd7313665.pngSpecify a drive letter. (Image courtesy of Microsoft.)
Step 5:
Select a file system for the volume. Your options are ExFAT or NTFS. Use ExFAT if you\'re going to share files with a Mac computer; otherwise, NTFS is the better choice. Unlike its predecessors, ExFAT can support the same volume sizes as NTFS -- up to 256TB. However, it\'s not as robust as NTFS and doesn\'t support file system-level encryption and built-in compression. Mac computer\'s can\'t write files to an NTFS drive.
9a87dfc0-3bf5-43bc-9c8b-f51801f8795b.pngSelect a file system. (Image courtesy of Microsoft.)
Step 6:
Select the "Perform a Quick Format" option if the drive doesn\'t contain any private information, or if you\'re using the drive for your personal use. A Quick Format takes only a few seconds, but the data it leaves behind can be easily recovered by anyone with the right software. A full format takes much longer but it does erase every byte of data. Select the "Enable File and Folder Compression" option if desired. Type a name for the volume and click "Next."
3e35ad5c-5391-4201-a130-a49a67a41fd4.pngChange the volume label if desired. (Image courtesy of Microsoft.)
Step 7:
Click "Finish" after reviewing the settings that were applied to the new volume. If you want to change anything, click the "Back" button and format the drive again.
777198bd-fcb2-4516-b752-36d350d7ca61.pngClose the New Simple Volume Wizard by clicking "Finish." (Image courtesy of Microsoft.)
Step 8:
Select another drive or volume to format, or exit the Disk Management utility.
Read more : http://www.ehow.com/how_6026_format-hard-drive.html
Tips & Warnings
  • If you\'re formatting a drive to give to someone else, or if you\'re disposing of a drive that has sensitive information on it, you should always deselect the Quick Format option so Windows can perform a full format. However, even a full format may not make the data completely unrecoverable. The only way to be 100 percent certain that data can\'t be recovered is to destroy the drive.
References:
Microsoft Windows: Create and Format a Hard Disk Partition
Jan 09, 2015 | Western Digital WDBPCK5000ABK - 500 GB USB...
I have made a disk image, with file extension .wmf, but don't know how to open it and get all the disk data back ??
wrong file extension. if you made a image of the OS it should have been a .iso this is burnable and easy to open with winrar or a dvd burner program for image burning.
The ISO file type is primarily associated with 'ISO-9660 CD Disc Image'. A literal dump of the data on the CD, byte-for-byte. The data is stored in the ISO-9660 format. IsoBuster can interpret these files directly.
The .wmf file type is primarily associated with 'Windows Metafile' by Microsoft Corporation. Microsoft graphic format. Xara X is a good program to edit this file type if you don't have Microsoft tools. There are several versions of a Metafile; each having a different header structure.
Jan 25, 2012 | Microsoft Windows XP Professional...
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps you
Oct 19, 2011 | Computers & Internet
How do i format a system using window 7 as operating system
Hi.
To format the hard drive and reinstall the system you need either a Window 7 install disk or a HP Windows recovery disk for your laptop model.
See links below:
Installing and reinstalling Windows 7
Windows 7 Installation
If you instead need to format an external hard drive, such as an USB disk, click right mouse button on top of the drive icon and choose 'format' from the dropdown menu.
I
Jul 07, 2011 | HP 530 Notebook
How can i remove microsoft windows 2000 form a dual boot system
Just start windows XP. Open Explorer go to menu: Tools - Folder Options Select : View Tab Select : Show hidden files and folders Click OK In explorer select C;\ Look for file : boot.ini Open boot.ini for editing (double click) CAREFULLY remove the line which looks like : multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" Close notepad, select SAVE Reboot You will not have the option to start windows 2000 anymore. On your desktop right click: My Computer and choose "manage" Select: Disk Management Select the partition where Windows 2000 was (is) installed. Right click and choose format You can now use this partition to store data and or programs
Feb 01, 2011 | Microsoft Windows XP Professional
How do i format my computer?
Open "My Computer".
Click with the SECOND (usually the RIGHT) mouse-button on the icon for the 'C:' drive.
Choose 'Format'.
The "format" process will write blocks of data, filled with "zero" bytes, over 100% of your disk-drive.
When the process completes, you'll have to re-install Windows onto this newly "wiped" disk.
Nov 26, 2010 | Microsoft Windows XP Professional
Format fat32 in vista for external hard drive
Click on Start > All programs > Accessories > right click on cmd. Select run as Administrator. Open it and connect your external hard disk. Then give the following command: Type format f: /fs:fat32 /q. In this the f is the drive letter of your external hard disk. The windows utility will format the disk and convert it to a FAT32 partition type.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
How to format? ned help
  • Open my computer
  • right click on any drive you want to format
  • then click format
For more detailed description of the drives and unallocated space on your hard disk
  • Right on my computer icon,
  • Click manage,
  • then a window would open with a menu on the left.
  • click on disk management
  • then you would see all your hard drive partitions on the right
  • now right on any of the partitions you want to format
Mar 17, 2009 | Microsoft Computers & Internet
Requesting answer
Negative miniscus doublet lens,Objective (disk read) lens,negative cylindrical lens,Negative elliptical lens.
yes
Apr 21, 2008 | Microsoft Windows Vista Ultimate Edition
Kingston DataTraveler 101 G2 Logo
74 people viewed this question
Top Kingston Electronics - Others Experts
Jerry Umali
Tony
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
