Question about Sharp AF-S120FX Air Conditioner
AY-X24LCJ H6 display stops working
No instructions in manual regarding H6 displayed on unit
2 Suggested Answers
scrodamoon
  • 659 Answers
SOURCE: Unit in room displays fault
Do not allow the signal receiver window to receive strong direct sunlight, since it can adversely affect its operation. If the signal receiver window is exposed to direct sunlight, close a curtain to block the light.
Using a Fluorescent lamp with a quick starter in the same room may interfere with transmissions of the signal.
The unit can be affected by signals transmitted from the remote control of a television vcr or other equipment used in the same room so make sure if anything recently added to the room is un plugged for testing purposes.
Do no leave the remote control in direct sunlight or near a heater also protect the unit and remote control from moisture and shot which can disclour or damage them.
Check whether the remote control batteries have become old and weak. (replace with new ones)
Try to send the signal again with the remote control pointed properly towards the units signal receiver window
Check whether the remote control batteries are installed with the polarites properly aligned
This could also be a result of the error locking out the remote as well so keep this in mind.
Also if possible unplug it and let it sit for atleast a day then plug it into a different outlet (if possible) to see if there is any change in the units functionality.
After that I would have to say check the area around the base of it and make sure that there is no moisture damage to the unit.
A good cleaning could be in order as well.
then if all else fails and the error presists contact customer service with the issue of the machine they will know what the error codes are.
hope that helps let us know how you make out.
Posted on Aug 02, 2008
Hi,I have a gree Airconditioner and its displaying H6 error,what should I do?
Google search your manufacturer make and model and the words error H6. You can find it in the search results, which will get you started.
Apr 01, 2015 | Heating & Cooling
Sagisag ng kromatiko
This doesn't seem to translate very well, but it seems like you might be wanting to switch your display to black and white or the reverse of that. This is typically done by adjusting the saturation to zero, and it will likely need to be done via adjustment of manufacturers display driver vs the Microsoft driver.
Ito ay hindi tila napaka-translate na rin, ngunit ito ay tila tulad ng sa iyo ay maaaring kinakapos upang ilipat ang iyong display sa itim at puti o ang reverse ng na. Ito ay karaniwang ginagawa sa pamamagitan ng pagsasaayos ang saturation sa zero, at ito ay malamang na kailangang ma-tapos na pag-aayos ng mga tagagawa display driver kumpara sa mga driver ng Microsoft.
Jun 09, 2013 | Computers & Internet
Fault code h6
Hi my washing machine ( a swan sw3010b ) keep draining the water and after a while it shows a foult IE. Can someone helps please
Nov 14, 2011 | Washing Machines
Videocon Split AC, Model VBS53 showing H6 Error. Please Help
h6 problem create a machine showing a display?
Jul 01, 2011 | Heating & Cooling
Only works in ''Tuner'' mode with ALARM on display
I called the dealer and he told me that the CD-Receiver is sensitive to voltage and it is possibly locked due to an unexpected rise during ignition. The unit has a reset button on the AUX (mini jack) port and after reset, it begun to work properly again. Only trouble now is I have to set my sound and tuner preferences again. No problem :-)
Apr 08, 2009 | Kenwood Car Audio & Video
Intermittent display of stats on information display unit in Maz3
Found instruction on removal of display unit and able to check for loose wiring, quite simple really, now waiting to purchse another unit. Note that previous solution in regard to swapping fuses did not work. Terry
Apr 05, 2009 | 2005 Mazda 3
LCD NO DISPLAY
Hi rldator
Laptop have a built in micro switch that puts the laptop in sleep mode when you close the notebook.
Regards Go-Tech
Dec 30, 2008 | Dell Computers & Internet
DWD1210S/1210W
H6 is an error code with the heater - you will need to get a professional to look at it.
We have one of the machines and it has been trouble since day one. We will not be getting another.
Aug 17, 2008 | Washing Machines
Sharp AF-S120FX Air Conditioner Logo
22 people viewed this question
Top Sharp Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
