Question about Dell A940 All-In-One InkJet Printer
Will not communicate with computer - Dell A940 All-In-One InkJet Printer
  • ecfirefam Mar 26, 2009
    I have the same problem. I have uninstalled, deleted, and reinstalled the drivers. It has not worked since then. Is there a dependency issue that I may have overlooked??
    Drivers have been uninstalled and reinstalled many times over without any results. What else should I be looking at? The computer tells me I do not have a printer installed.
    President:
  • 2,692 Answers
My computer cannot detect my scanner. Error Code: 0x0070800
The FB320P is a parallel port scanner and is having problems communicating with the computer. Are you connecting it directly to the parallel port on the computer? In that case, you may not have bi-directional communication enabled. Turn off the scanner and the computer and disconnect the data cable from the computer. Turn on the computer and enter the BIOS. (Press Esc, F1, F10, or Del repeatedly after you turn the computer. You should see a screen with the correct key to press; it varies depending on your BIOS and motherboard. If you miss the timing, shut down the computer and try again.) In the BIOS, search for the parallel port settings and see if you can enable bi-directional communication.
Not all parallel ports support bi-directional communication. If you can't enable the feature, you need a different parallel port. Try a PCI slot add-on card; just check the features and check the manual for enabling bi-directional communication.
If you are using a USB to parallel port adapter, get a different one that supports the bi-directional communication.
What OS are you using? There are a few that had ASPI driver issues; a third party app, ForceASPI, may help. See http://www.afterdawn.com/software/cd_dvd/dvd_tools/frcaspi.cfm for information.
I hope this helps. Please add more information about the configuration (cable, OS, etc) for extra ideas to solve the problem.
Sep 16, 2012 | Canon CanoScan FB320P Flatbed Scanner
Lexmark X1190 problem communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
Dec 20, 2011 | Lexmark X Office Equipment & Supplies
I got a code from auto zone that is i believe UO 101 AND UO105 OR UA101 AND UA105 WHAT do these codes stand for
These codes are communications code errors:
The UO101 is a transmission communication error: poor communication to your transmission ECM / computer
The UO105 is a fuel injection communication error: Poor communication to your fuel injector ECM/ computer.
Jun 15, 2011 | 2006 Dodge Stratus
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Computer isn't communicating with my printer
    computer is not communicating with my printer i unplugged the usb port i and i resart the computer
    Aug 31, 2008 | Nikon COOLPRINT Thermal Printer
    Computer will not communicate with printer
    Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
    Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
    X2250 not communicating
    will i think theirs two posible options why not communicate the printer first not proper installed the printer driver or maybe your connection from the computer to printer will loss contact that why not communicate...
    Nov 27, 2007 | Lexmark X2250 All-In-One InkJet Printer
    Dell A940 All-In-One InkJet Printer Logo
    100 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
