Question about Mackie DLM12S - 2000 Watt Powered Subwoofer
Mackie dlm 12 stopped working after a half an hour. What's wrong with it?
Getting no sound coming out
  • 56 Answers
Why does my mackie cfx12 mkii have low output across all 8 xlr inputs at unity gain with distortion above that?
Where are you getting the low output? It would be very strange if all channels failed in the same way so it is probably something common to them all. Can you get the clip light to illuminate at all by turning the gain up on a mic channel and shouting into the mic? You are referring to the gain at the top of the strip not the slider aren't you? What happens if you assign a channel to the other sub channel, does the level come up through that? What happens if you take the output from the aux send and you send signal there, is it the same issue?
I may be completely wrong but I suspect if it is only mics that are causing a problem you may have the routing set up wrong or not set a level somewhere else right.
Aug 10, 2014 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
Mackie CFX12, right side output not working? Help!
Assuming if you pan hard left on an input it comes out the left and panning hard right goes nowhere and as you say the tape input feeds through to both sides OK there is a very limited number of places where the problem can be. If you are confident open it up and check all the connectors and cables. If anything has come loose this may find it, otherwise it's a trip to the repair shop. The largest cost will be the taking apart and putting back together as the repair itself should be a simple one and diagnostics easy.
Apr 11, 2013 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
The mute button cuts the main audio but the effects audio is still heard. What to do?
That's basically normal actually...however it depends on which aux send you're using. If you use aux 1 for the effects, you can use the pre/post switch on the master aux 1 send to switch it to pst fader....now your mute switch should kill the effects as well. Aux 2 is good to use for monitors where you don't need to return them to the mixer.
Mar 25, 2012 | Mackie 1202vlz3 12 Channel Mixer
I have a mackie cfx 16 mixing board.My problem is that , the only way I can get a good signal to the led's for each channel (0 db) is to turn the gain up so high on the channel that it constantly...
No reason to worry about getting signal to the LED's... you set the trim gain so the loudess sound or signal that can happen barely clips or is slightly less. That is the starting point. Watch videos on mixer setup on YouTube. DOn't worry if their mixer is different as the principles are the same.
Mixer fadrs should be around 80% up when system is balanced. ALWAYS use BALANCED cables... eithrt XLR or TRS.
Aug 21, 2011 | Mackie CFX 16 mkII 16 Ch. Compact SR Mixer...
ONLY GETTING MUFFLED SOUND FROM ONE OF MY MACKIE SRM V2 SPEAKERS,HAVE CHANGED DIAPHRAM BUT PROBLEM STILL THERE
If you've changed the tweeter and the sound is still muffled the fault is with the HF amp, or the cross-over. You will have to send the amp assembly for repair as it is all surface mount components in there -nothing you will be able to fix yourself. Sorry for the bad news!
May 04, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
I used my monitors at high volume for approximately 1 hour and they stopped working. One monitor has no volume and the other has very low minimum volume.
You may have blown a fuse in the amplifier. Refer to Appendix A: Service Info in this guide http://www.mackie.com/products/mr5/pdf/mr5_om.pdf under No Power section, and if the fuse it not blown, try some of the solutions under No Sound. Hope this helps!
Feb 28, 2011 | Mackie Mr5 Active 5" Powered Studio...
Computer->M-Audio-FastTrackPro USB->trs outputs 1/2->linein 11-12 of mackie 1202-vlz3. How can i get stereo sound out of the mackie?
Use TRS to TRS balanced cables from the M Audio to the line in 11 and 12.
Set the pan controls for the 11 and 12 to opposite directions to split the stereo to left and right main outputs. (otherwise both main outs mix the left and right and you get mono result.
Feb 05, 2010 | Mackie 1202vlz3 12 Channel Mixer
I have a Mackie cv1604 which suddenly stopped working. all lights on the channels light up and no sound. help?
same problem here.. gimme a holler if you've figured anything out.
mine, channels light up, it's getting sound (input) from mics, but it's no sound coming out. i'm almost definite the problem is with the main mix slider. but then again i could be wrong.
Jul 10, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
No sound in left channel
If you are looking for the service information for a Mackie 1202VLZ, contact Mackie. I believe that you can purchase it directly. They have contact information on-line.
Dan
Feb 10, 2009 | Mackie 1202vlz3 12 Channel Mixer
Mackie DLM12S - 2000 Watt Powered Subwoofer Logo
111 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
