Question about Cameras
Can not get my card to work.its a cardbord one
  • Cameras Master
  • 32,281 Answers
Try formatting the memory card.
Go to the camera's Menu then scroll through the settings to Format memory card.
Posted on Apr 20, 2013
2000 Mazda 626 where is security fuel cut off switch located
in your trunk behind the cardbord on the side where you fill up
Aug 08, 2013 | Vehicle Parts & Accessories
I've got an oil leak on the left side lookin at the motor, but I cant tell where it is
if you can't see or tell where the oil is coming from, after the car has ran for a while, shut the ignition off and , put a large piece of cardboard under the car, start it back up, let it run for a whiile and check the cardbord to see if you see any oil on it, if not, then let the car sit over night, if leak still persists, then you should be able to see oil on the cardboard, then check area of where oil leak was on the cardbord.
Feb 19, 2011 | 2000 Mercury Sable
How to replace turn signal in the rear of my pontiac grand prix
open trunk and remove the cardbord/carpet cover right behind the tail light and you will see 3 plastic wing nuts remove the nuts and then remove the tail light assy. then it will be self explanatory how to change the bulbs.....GOOD LUCK
Dec 23, 2010 | 2004 Pontiac Grand Prix
How do you get to the rear struts on a 2003 taurus
to get to the top nuts you have to get in the trunk and remove the cardbord/carpet cover that is over the wheel well to get to the bottom bolt remove the wheel and it will be right in front of you...BE CAREFUL struts can be DANGEROUS
Nov 14, 2010 | 2003 Ford Taurus
Water is leaking out of my 2001 Plymouth neon. I have to constantly refill the radiator and coolant resevoir any suggestion what might be the problem?
It sounds like you have a leak. I have seen the water pumps go bad many times. However I would inpect hoses and hose clamps. If okay place a piece of white cardbord under vehicle. Let vehicle idle for 20-30 minutes and inpect for liquid to hit the ground. Once found see if you can locate where the leak is coming from. If you don't see any coolant leaking I would supect a leaking heater core or leaking headgasket. You can also have a shop pressure test the radiator if none of the above works.
Oct 24, 2010 | 2001 Plymouth Neon
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
I can't get it to quit leaking on the top... the gasket is getting bad, maybe... do they sell repolacements?
you could get one or make one from a cardbord box and coat it with silicon gasket sealer
Jun 25, 2010 | Sunterra 3000 GPH Pond Pump 203000
Form feeding
try puting a piece of cardbord under the paper but tape it 3mm from the roller.
Jul 31, 2009 | AMT Datasouth ACCEL-6350 Matrix Printer
Flashing E3 error code for a paper jam
I had the same problem with my mp 160, Error message was blinking. I tried to print but the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbord(I used a magazine cover), cut it in a size of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine. Hope it does for you.
Mar 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Do I have to remove the cardbord covering from the phone battery first. It's in a Motorola W180
what covering the battery you should be able to just take thebattery out with out what ever carboard you are talkinng about
Dec 12, 2008 | Motorola Mobility RAZR V3
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
