Question about Nikon Coolpix 7600 Digital Camera
The zoom is stuck in the out position and will not retract back into the camera!
  • mari_huie Mar 12, 2009
    will try that as soon as i find an air compressor....will try my dentist!!!! thanks
  • martacanova May 12, 2009
    dopo aver caricato le foto sul pc,la macchinetta si è spenta con l'obbiettivo fuori e non si accende più.
  • 423 Answers
Hi there, welcome to FixYa.
The problem your having is that sand and/or dirt gets in the lens mechanism of the camera. When the little cog inside gets sand or dirt in it, it prevents it from moving. It is what causes 95 percent of all lens errors. The other 5 percent are when the guide pins get misaligned and don't go back in the tracks properly. Mis aligned pins happen alot of times when you drop it with the lens extended, so let's go with the easy one first.
Take an air compressor (or borrow a friends) and put the nozzle up to the space in between the lens and and the camera. Blow it out real good. It may take a couple of tries, but it should free it up.
Let me know if that helped, and feel free to rate my answer.
Posted on Mar 11, 2009
  • Rob
    Rob Mar 12, 2009
    LOL, here is a solution that might be abit more expedious for you. Use a hair dryer on the highest setting. Blow air into the space I mentioned in the earlier post, then turn the camera lens down and gently tap the lens on a hard surface. This might work for you instead of having to make a dentist appointment! Hope this helps. Try it, if it does, then if you feel so inclined, you can change the rating. Thanks,
When using the zoom control, why does the lens zoom out but will not zoom back in with the zoom control?
your camera's zoom is faulty, there is some sensors with which controls the lens retraction, if the lens's position is wrong the sensor cutting edge will not get in the proper position.
open the camera, take out the lens, open it carefully, if the position of the lens is not in proper position, you can see some marks on the lens barrel fix it in the correct position.
Feb 25, 2016 | Nikon COOLPIX Cameras
Lens problem, turn camera back off then on message
That usually occurs after the camera has been dropped or dirt is stuck inside the moving parts. I have had this on two cameras; one was filled with dirt, and eventually started working again. If you can try to clean it while it is fully extended and retracted you may be able to get away with a simple fix. Cleaning it in one position may be impossible.
My other camera was dropped into dirt (with a lot of force...fell on it). After trying to clean it with the above method I was able to get it to finally work. The clicking you hear is the zoom mechanism binding on 'something', which is either dirt or a bent or broken part inside. After a few seconds it will shut off to prevent causing further damage.
Jun 19, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My samsung pl50 won't turn on it just bleeps at me when i try and the shutter is stuck out. it was working fine when i was taking pics of my sister then it just shut down n won't turn back on
I've sent back 2 phones with this exact problem. Came on here and found the solution on the blog from another camera. It works! Here it is:
Figured it out....the zoom lense, while in the open position, was a little out of line, thus preventing the camera from retracting it. After gently re-aligning the lense, it retracted properly and the camera resumed normal functioning.
So basically, wiggle the lens every so slightly then try the power button again. Hope it works for you!
Jun 05, 2010 | Samsung L200 Digital Camera
Camera lens stuck
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 30, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens won't retract, stuck in outward position
battery power/and or lens motor/ if lucky the lense connection, (Try removing the lenses and puting them back) may be a bad electrical connection.
Aug 11, 2009 | Kodak Easyshare Z812-IS Digital Zoom...
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Zoom wont adjust
Hi there. I can help you with that.
The number one problem with cameras with lenses that won't retract or or move out into position is dirt, grit or sand in the lens mechanism. The best way to fix this is to get an air compressor and put the tip up the lens and blow air into the space around the lens. Run the tip of the compressor nozzle around the lens and turn the camera back on. See if that helps. If it doesn't do it one more time.
If it helps, great. Stop there. If it doesn't help, let me know in a comment and I will tell you a couple more things to do. I want to wait, because they are things that you should only try if you are ready to trash the camera, but they usually work. Hope the air compressor works.
Feb 21, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Zoom and camera shuts off
Verify you have the right kind of battery and fully charge it.
The lense issue you describe commonly happens when the device cannot access enough power to function correctly, so it retracts and powers off to avoid getting your lense stuck in the 'out' position if the battery goes dry.
Apr 27, 2008 | Kodak EasyShare One Digital Camera
Zoom lens won't retract and stays out
check to make sure the battery is in right. also make sure the memory card slot is closed.
Dec 04, 2007 | Canon PowerShot SD850 IS Digital Camera
Nikon Coolpix 7600 Digital Camera Logo
202 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
