Question about Philips Magnavox DVD/VCR Dual Player
DVD PLAYER MODEL DP100MW8B AND DON'T HAVE MANUAL BOOK
WAS WONDERING HOW DO I CONNECT JACKS FROM DVD PLAYER TO HDTV TO VIEW MOVIES. I HAVE THE YELLOW, WHITE AND RED JACKS THAT DIDN'T WORK WELL AND BROUGHT THE BLUE, GREEN AND RED JACKS. PICTURE IS STILL NOT COMING IN GOOD. ONLY SHOWING BLUE AND YELLOW.
5 Suggested Answers
  • 85 Answers
SOURCE: No picture or sound magnavox mwd200g dvd player
on the side of the tv mostly there is a button for dvd mode you will have to press that button to reach in dvd mode.if no such button then its the cables fault or the wires are not connected properly just check out this link for connections
For tv/dvd /vcr connections
http://www.funai-corp.com/support/setup.aspx?prod=dvd2tv2vcr
For tv/dvd /vcr question answers.
http://www.dvddemystified.com/dvdfaq.html#1.27
Posted on Mar 02, 2009
  • 192 Answers
SOURCE: Trying to hook up the dvd player to the tv and I
Your TV probably has several different ways of connecting video. One is component, which uses three cables. They are red, green, and blue (RGB). The video output on your DVD player will match this color scheme.
Another scheme for video is composite (because it combines the red, green, and blue into one cable). Composite video is usually a yellow "socket". It is simpler to connect, but the video quality is noticeably poorer than component (RGB).
Another scheme is S-Video. This is one cable (round and black), but you will see four pins inside the connector (and four holes in the "socket"). This accounts for the three cables in the component scheme with the convenience of having only one cable. The picture quality is almost as good as component as well.
In your case, there may be confusion between composite and component. If you have red, green, and blue sockets on both the DVD and TV, then make sure you use them and connect them color for color.
Now for the sound, this is simpler. Red is the right channel, and white is the left. Make sure you connect red to red and white to white. Then, viola, everything will be right.
I hope this helps.
Posted on Aug 24, 2009
  • 101 Answers
SOURCE: Why can I only get a black and white picture? the
from your description the "unite" -, only the yellow plug has CVBS video signal.
The CVBS connectors are not standard on HD televisions....
buy one of these for your television and connect up matching colours:
http://en.wikipedia.org/wiki/File:Multiconnector-scart-chti.jpg
Posted on Dec 30, 2009
  • 81 Answers
SOURCE: Have a HDTV. Cable hooked in it. Have the yellow,
Just to clarify, you are not using a cable or SAT box? Coax running directly into the tv correct? If so, go to the Menu on the tv remote. Find and select connections and/or cable connections. Be sure "Cable" is selected and not "Air". Let it auto format after selected. When completed, you should be selecting "TV" from the Input selector on the remote. Usually the first in the list of Inputs. Let me know if this helped.
Not sure what you mean by Yellow, Red and White showing.
Posted on Jun 30, 2010
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Hook up vcr to hdtv we initaially got an hdtv tv and later bouht a vcs/dvd player. we do't know how to hook it up.
Look for A/V output from VCR/DVD (yellow, red and white RCA jacks). Connect to matching TV A/V inputs using A/V cables. Both manuals should illustrate this. Usually TV has DVD/VCR/AUX setting to view.
Jul 09, 2009 | Televison & Video
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Jan 30, 2009 | Televison & Video
Digix Manual/diagrams do not match my TV connectors
Simplest way. ++++++++++
If you have red, white and yellow on each match those and use a cable with 3 strands - red, yellow and white ends with RCA jacks. Use the setup key to get an onscreen display to set options.  Make sure they are the video/audio OUT on the DVD not in.
On your TV it's probably Video 1 or something like that - you can usually test this by putting the cables into the front of the TV. The TV remote might have some key like TV/Video to get to the Video input screen.  Make sure you check the video-in ports on the TV - not the video/audio-out.
Option if red is missing +++++++++++++++++ If the DVD player just has yellow and white then just connect yellow and white (it will be mono) on the TV.
It shouldn't matter if the holes are vertical or horizontal.
S-video +++++++ If both TV and DVD have S-video ports then connect those - they will give you better video than the yellow.
You will still need to connect red and white sound cables.
Jan 04, 2009 | Digix Televison & Video
Philips Magnavox DVD/VCR Dual Player Logo
200 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
