Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
DISPLAYING FRACTIONS AS ANSWERS
How do i set up my calculator to leave answers as fractions
  • 11 Answers
The TI 83, 84 series can not set up the answers as fraction. What you have to do to get fraction answer is to go to math,1. the very first selection which is ->frac. What will change your answers into fractions
Posted on Mar 18, 2009
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors.
At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers.
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.
There are now two options: 0: W-VIEW, and 1: LINE
Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.
To return to the WriteView display, go through the steps above but press 0 for W-VIEW.
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
How do i change the answers from fractions to decimals
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Oct 20, 2010 | Sharp ELW535 Calculator
With the TI-84 Silver calc: what I really meant was - I want to input a set of mixed numbers (or just a regular set of one or more fractions e.g. 3/4 x 5/87) and either add, subtract, divide (or any...
Upgrade the OS of the calculator to the 2.53 MP (Math Print) version. As you can see on the following screen capture of the MODE setting, you can choose to use the CLASSIC option (the old way) or the MathPrint version.
You should notice that the Answers AUTO DEC or FRAC options allow you to configure the calculator to work in DECimal, FRACtions or AUTO (the calculator chooses whats is appropriate).
The n/d is for improper fractions and Un/d for mixed fractions.
Enjoy your new found freedom.
Here is the link to the new OS 2.53MP
Mar 25, 2010 | Texas Instruments TI-84 Plus Silver...
Answers in decimals
The calculator has two Input/Output modes, MthIO and LineIO. In MthIO the results are displayed as fractions or as radicals or a mixture of fractions and radicals. What it means, is that in MthIO the calculator does exact calculations. Radicals in denominators are gotten rid of by rationalization, fractions are reduced to the same denominators before addition or subtraction. Fractions are reduced to simplest form.
In LineIO all results are displayed as decimal numbers.
If a result is exact (fractions and radicals) it can be changed to decimal form by pressing the S To D key, the one above the DEL key.
MthIO is the default IO mode. To set it, press SHIFT MODE and select 1:MthIO. To set LineIO as the IO mode, press SHIFT MODE and select 2:LineIO
Jan 20, 2010 | Casio FX-115ES Scientific Calculator
Setting the default value of my calculator to display decimals
Since you bent on deactivating the very features that make your calculator so versatile and so powerful, here it is.
Press [SHIFT][MODE][2:LineIO] and you will see no more fractions, nor radicals etc. You asked for it.
Hope it helps.
Oct 18, 2009 | Casio fx-300ES Calculator
Fractions
there is a A b/c button. This is the button use to enter fractions. so 4/3 would be entered as 4 |A b/c| 3
If you want to have the answers in fractions as well, then I believe you hit more a few times. And then there should be a display option, in the display option, there should be a b/c. This will show your answers in fractions. Hope it helps
May 05, 2009 | Casio FX-300MS Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Fractions multiplied by fraction to get fraction
In the CATALOG there is a >Frac command that can be used with parentheses to multiply fractions.
(1/2)(1/3)>Frac
1/6
Jun 18, 2008 | Texas Instruments TI-85 Calculator
Changing result display from fractions to decimals
Struggled with this and found answer on about page 19 of the instructions on the Internet. Answer also appear on paper instructions under: "Displaying Calculation Results...etc just under "Note" Trick is you must have calculator in "LineIO" mode For setting MODE see "Calculation Modes & cal. Setup in paper instructions.
Jul 09, 2007 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
644 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
