Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi WS-55511 power problem
I have a Mitsubishi WS-55511 tv that when i push power the light comes on for a second and then turns off. I did the diagnosis test and it gave me the 1 blink and then 2 blink meaning no error. Any ideas how to fix this?? Thanks!
SD Tech
  • 14553 Answers
SOURCE: My Mitsubishi ws-55511 does not turn on. I push
1.) 2-2 is short protection and usually means one of the two fuses that protect the convergence IC are bad.
2.) This model uses a Single convergence IC--A STK-393-110 THAT can be purchased for about 14 dollars plus shipping on ebay.
3.) If one of the fuses that protect it is blown the set detects no voltage present and shuts down instantly.
4.) I have photos of what the fuses that need to be checked look like; also there are several protect resistors around the chip that need to be looked at also--I have photos of them also.
5.) I also have step by step start to finish instructions for this repair for this model--It tells you how to do the repair and everything you will need to do it.
6.) If you want the photos and instructions give me a vote here and I will email them to you free.
7.) I do this here for free so if this has been helpful take a minute and give me a vote here.
REGARDS, SD TECH
Posted on Sep 13, 2009
Testimonial: "This was a great step by step answer to my problem. Thanks!"
SOURCE: Mitsubishi WS48511 TV will not power on completely.
I am having the same sort of probblem
TV stays on for awhile and then powers itself off and won't come back on for awhile then will work ok again.
any ideas
Posted on May 21, 2008
Slinteriors
  • 8617 Answers
SOURCE: ws-55511 power problem
Ok the 12 code means no error detected. Try this you will see three small wire plugs that run from the convergence yokes on the picture tubes. not the three big plugs, they will be real small plugs all identical. try unplugging them and then try powering up the set. But remember where each one was plugged so you can plug them back in correctly.
Posted on Aug 03, 2008
  • 126 Answers
SOURCE: powers on for three seconds then goes off
The first thing to do is to try to determine why the set is not turning on. It is equipped with a self diagnostic feature. On the front of the set push the MENU and DEVICE button at the same time and hold until the LED starts flashing a two sequence code. That will narrow things down for us.
Posted on May 05, 2009
SD Tech
  • 14553 Answers
SOURCE: My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Posted on Aug 08, 2009
When you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the tv for about 3 to 5 minute
Do this: When you turn it on and the green power light comes on and goes off:
On the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and then release both.
This model has a self check: The green power light will then blink a two digit error code: most common is 2 blinks, 2 blinks and a pause and repeat the error code at least 5 times.
Let me know what you find and I will tell you what it means.
I hope you get 2,2 as it is the most easy to resolve.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Turn on the tv a few seconds later it shuts the power light blink
Replace both of your convergence ICs they are STKs big black ICs will have part number on them.
Jun 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Powers on for three seconds then goes off
Apr 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511
Press in together the menu button and the Device/input button on the set and hold them both in together for 5 seconds and see if the led will blink a two digit error code, then respond to this same post and let me know if it gave a error code and what the two digits were.
Aug 02, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
