Question about Dell Inspiron 2650 Notebook
Hi, In the process of upgrading the memory on my Dell Inspiron 2650, I broke the tabs on the keyboard connector that holds the Keyboard ribbon cable to the Motherboard. With advice from all places, I've completed the memory upgrade and it all works.(To 512 Megs from 256) However after the third time taking it all apart the connector was a victim of my ignorance as to how it worked. So, I am trying to find a source for just such a connector.The cable is fine and the part of the connector mounted on the Motherboard is OK I just need the part that holds the cable in place. If you know of any source or part number that would help please let me know. Thanks, freedivedoug
  • freedivedoug Mar 16, 2009
    Thanks for your input.
    I thought I might be able to buy a connector but I guess that's not
    the way things are.
    I'll probably take your advice and purchase a whole board.
    Thanks again,
    freedivedoug
  • freedivedoug Mar 28, 2009
    I did purchase a "new" 2650 Board on ebay but it didn't fit - The connector was different.
    I thought they had sent me the wrong one but there may be more than one correct "2650" keyboard and connector.
    While looking through a ton of old junk notebook computers at a
    computer re-cycling center, I found one 2650 with the keyboard gone
    and it appeared to have the type of connector like the one they sent me.
    I'm trying to get a picture of mine to send to the ebay company where I purchased mine . They are very helpful but need to see what I've got.
    I'll let you know what I find out.
  • 211 Answers
Replace keyboard.
Posted on Mar 11, 2009
  • aliokas Mar 16, 2009
    Keyboard are not expensive, so i dont think that separate connectors are available to buy.
    No problem, please rate.
Dell mini 1018, upgraded memory to 2gb, worked fine except ribbon cable connector broken. Where can I get another 1 cent piece of plastic, or should I just use a usb keyboard?
I encountered a novel way to resolve that issue on an Inspiron 1110, where the person working on it had also broken the Keyboard cable connector clip. They used clear packing tape to hold the ribbon cable in the connection. It may take some diligence, but you may be able to get a decent cable connection that way.
Jul 12, 2011 | Dell Mini 1018 Notebook
Where is the memory slot located on inspiron m5030 and where can i get instructon on how to replace it and upgrade it.
there may be one located under the keyboard...there should be screws on the bottom that have a keyboard symbol next to them..remove these to remove the keyboard and carefully lift the keyboard to avoid pulling on the ribbon cable
Mar 26, 2011 | Dell Inspiron M5030 Laptop
How to remove Insperon 1725 keyboard
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Oct 30, 2009 | Dell Inspiron 1526 Laptop
Keyboard connector on motherboard dell inspiron2200
personnally I would not try this. If this is the only laptop you have. now if its just a machine you tinker with you can try it. but for functunality I would leave the keyboard intact incase you ever want to use the portability of the laptop.
Apr 16, 2009 | Dell Inspiron 2200 Notebook
My dell inspiron 2650 it seems as if the laptop keyboard has locked up. Wont type at all or let me in the computer with a password at all. help
It sounds as if your keyboard might not be connected any longer. This might be the result of a sudden jarring motion to the laptop, or a drop.
http://support.dell.com/support/edocs/systems/ins2600/en/sm_en/keyboard.htm#1005330
Use the above illustration to lift out the keyboard and make sure the Keyboard flex cable is attached to the connector (scroll down at the site listed above to see illustrations of the cable and connector).
The same link shows how to connect the flex cable, if it is disconnected.
Hope this helps.
Dec 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Keyboard want work
The keyboard is probably broken or the cable is loose (unlikely) from the motherboard. Does the keyboard work at all? at any point?
Try a external keyboard, usb for example and see if that works.
Nov 15, 2008 | Dell Inspiron 2650 Notebook
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Keyboard
Try this:
Shut down, unplug the AC adaptor, removed the battery, and hold the power button for up to 1 minute to discharge.
Make sure there are no stuck keys.
Restart.
Apr 08, 2008 | Dell Inspiron 2650 Notebook
Laptop Keyboard Not Functioning
Try to unplug and plug back in the keyboard connector ribbon onto the motherboard. Consult the laptop manual if that voids your warranty or not before trying, also look at the documentation on how to dissemble your laptop, it shouldn't be too hard. here's the instructions on how to do it
you might need some tools, but good luck and be careful
Dec 22, 2007 | Computers & Internet
Dell Inspiron 2650 Notebook Logo
101 people viewed this question
Alun Cox
