Question about Dell Computers & Internet
How do i make an older PC run faster?
I just bought an older Dell off of someone today...it's pretty much a dinosaur. This thing 'appears to be' clean..but it takes forever to start & a long time between *mouse click to actual program response* i threw an additional 512 stick of ram at it...but the differences were only subtle. additional details: its running Win XP, came with 256mb RAM (laughable) ..and a 40 gig HD,..not sure of the processor etc..it took too long & i got impatient. thanks..any help is appreciated
    Master:
  • 663 Answers
I suggest that you reinstall the operating system of that computer and upgrade the Memory stick and hard drive. However you have to make sure that the computer can handle the upgrades. What is the manufacturer of the computer?
David
Posted on Apr 20, 2013
  • 5 more comments
  • Andrew Wyeth Apr 20, 2013
    It is a Dell, but i am unsure of what model #..etc (thanks for the response, btw
  • David Greene
    David Greene Apr 20, 2013
    No problem. The first thing that you can is to reinstall the operating system and install the drivers. You also have to make sure that the drivers are up-to-date. That would make your computer run faster. You can use RadarSync to automate it. Don't buy hardware parts yet, they are expensive. You can start with the software side. It will surely speed up if you clean it up. And, tear down the computer and clean it. There are dusts inside and it can result to overheating which can result to freezing up or slowing down of your computer. Let me know if you have any questions.
  • Andrew Wyeth Apr 21, 2013
    well, i cleaned the internal components with duster. i did throw another stick of ram in, but neither really helped that much. There was a Windows XP installation cd that came with it, but when i tried to run it, it said something along the lines of "you are trying to install an older version" but wouldnt allow me to continue with the installation. I was gonna attempt a defrag, but it took so long to even load the screen..i just got impatient & decided i'd look for other options. i cant seem to get this thing running at a 'factory' speed
  • David Greene
    David Greene Apr 22, 2013
    I'm just curious about XP's message ""you are trying to install an older version" ... Did you insert the disc while XP is running? Or did you do the clean reinstallation? You should do a clean reinstallation . Boot to CD, then reformat. Don't overwrite the operating system.
  • Andrew Wyeth Apr 24, 2013
    yeah, while XP was running.... is there an option in XP to do the format? ..or do i gotta go oldschool ( in DOS typing: format c:/) ? ...it has been years since ive even messed in this area with computers
    ...how do i do a clean reinstallation WITHOUT overwriting? *thanks for all your help by the way, i really appreciate it*
  • Andrew Wyeth Apr 30, 2013
    Update: I managed to do a complete format & fresh XP installation by booting from the cd. Now it works like a dream!
  • 1003 Answers
SOURCE: not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Posted on Jan 17, 2008
wayneard
  • 1901 Answers
SOURCE: Dell optiplex p4 1.8ghz: RAM
Best and easiest thing to do is go to www.crucial.com and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
Posted on Jan 28, 2009
  • 22 Answers
SOURCE: dell 2400 ram upgrade problem
RAM can be finicky so first test all memory slots with a known good stick (your 512MB). Make sure you're starting from a complete power down and you get a POST beep (hopefully your system is set up to beep when it powers on) and everything loads up all the way through to your OS.
Once you do that with all your memory slots test with the new stick by itself in all memory slots. If neither of the memory slots work with the new stick but you verify that it works in another system you should then check your BIOS settings and RAM timings to ensure compatibility with your stick. If you can't find the timing on the RAM stick itself, look up the manufacturer's part number for the information.
Posted on Feb 03, 2009
sodeep
  • 3267 Answers
SOURCE: NO SIGNAL NO KEYBOARD NO MOUSE
Looks like one key on your keybord is constantly depressed specially if you are using a keyboard which is made by combining 3 layers of semitransparent plastic sheets with a rubber cup under each key. These keyboard fail without any warning and sudeenly one day when u switch on ur PC, it will make the motor, fan,running, but NO DISPLAY. Is this what has occured? If so and even if the PS2 connector of the keybord(if u are not using a USB keyboard), check for looseness or any bent pin. Remove the jack and try starting ur PC. If it behaves (soundwise & vibrationwise) as earlier then its definitely keyborad problem. If possible, before buying a new one try any keyborad which is working condition and check If problem remais, then do post your feedback & i'll try my best....sodeep
Posted on Mar 24, 2009
joeshea123
  • 65 Answers
SOURCE: Windows XP pc running very slowly
To make your system run faster there are few things you can try.
1. clean out as much things from starting during system startup.
2. check your user profile, reduce your profile as much as possible. create a folder on the root of the C-drive and move as much stuffs off your desktop and mydocument.
3. Make sure you have enough disk space.
4. you can try to increase the virtural memory a little more.
5. last thing is get more memory.
Posted on Mar 31, 2009
I have just bought a Dell Precision 390 its a refurb. The problem i have is that the case fan goes into override and runs at max after about 5-6 min. This can be on idle or if a program is opened. I w
You may also want to remove the CPU heat sink and apply more thermal paste to prevent any overheating. You can buy the paste from radio shack for about $10. Arctic Silver 5 is the best stuff.
Jan 13, 2013 | Dell Precision Computers & Internet
Hi - hoping someone can help, Have recently purchased a Dell Inspiron N5110 which booted windows fine the first time I switched it on, set up all worked and seemed to be fine. Now when I try to start up...
Hello!
How long ago and from where did you purchase this device?
Suggested solution:
If within time limitations set by seller, return item as D.O.A.
and demand an immediate replacement. It's the MORALLY correct thing to do...
Nov 23, 2012 | Dell Inspiron 14r N4110 2.00ghz B940 4gb...
Slow
Toshiba 1805's are older, PIII (or Celeron) based computers. Two things you can do to make these babies run fast: first and foremost is to max out the RAM to 512MB - that will usually do it - as most of the 1805's that I've seen are still running with 256MB, which is simply inadequate; the other, of course, if to put in a faster hard drive (5400rpm or higher). If you do both, these machines can still be pretty potent...
May 06, 2010 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
The patch for fixing the sound does not open
Most of the DK software was made for older computers that interacted with sound card hardware almost directly.
Todays sound cards are much more advanced.
DK also dont have much support for older oftware and even went third party for distribution etc.
If you have an older computer eg windows 98 tyhen it would probably run fine.
You could even try running it in compatibility mode under vista but I doubt it will fix your issue.
Sep 09, 2009 | Dk Multimedia Dinosaur Hunter Deluxe...
Mar 31, 2009 | Dell Dimension 4600 PC Desktop
Computer running slow, how can I reboot and get rid of extra junk
Run a defrag on all your drives and clean up temp files. There is a free utility that cleans up pretty good and it's called CCleaner.
It's very important to defrag the HDD though.
Bye.
Mar 30, 2009 | Dell Dimension E521 PC Desktop
Computers & Internet Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
