Question about Ryobi Backpack Blower 25.4cc
Someone ran gas instead of 2-cycle in leaf-blower; now locked up
Ryobi Leaf-Blower; new; need information on how to try to free it
  • 63 Answers
It's probably dead. If the rope won't pull buy another and keep it for parts, the repair bill will be more than it costs. Spray some wd- 40 in the spark plug hole and let it sit for a couple days, IF it frees up you got lucky but don't expect it.
Posted on Mar 16, 2009
Backpack gas blower
Monching, You will have to hope there is not too much damage done already from running straight Gas. Empty all straight gas from blowers tank and refill with proper minimum 50:1 gas oil mix. Start blower and run on 1/2 throttle for a few minutes to be sure its going to be OK. If seized, you will have to try and unseize and if lucky it may run if not too much damage internally. You should run a heavier oil to gas mix 32 or 40:1 in an engine that's been seized. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
this is what happens when someone run straight gas in two cycle engine
Fixing seized up echo weed eater
Stihl FS120 Grass Trimmer RAN WITH NO OIL IN GAS Blown Top End
https://www.askmehelpdesk.com/tools-power-equipment/ran-leaf-blower-without-oil-36071.html
Jul 12, 2016 | Craftsman 25cc 2-Cycle Gas Blower/Vac
I have a factory refurbished Ryobi ZR08510 blower/vac from the factory. I cannot get it started. What should I try first?
Hi Paul:
I'd start by pulling the spark plug, attaching it to the lead, then spin it over and check for spark.
This will probably be a 2 cycle motor (Check to confirm) so make sure your fuel is mixed correctly.
Dec 30, 2015 | Ryobi Blower Vac 205mph Leaf Blower Or...
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
How to start ryobi leaf blower model 09050 i tried everything i primed it with gas tried shooting starter fluid in it
Do you have a spark on the plug? Did you use gas-ethanol mix?
Use premium only.
Sep 12, 2015 | Ryobi Garden
My ryobi 4 cycle leaf blower will not run over approximately 8/10 minutes and then will not restart for possibly a day or so.what can be done"
you have 1 of 2 possible problems. First is the ignition module is getting hot and killing the machine. It runs while cold but once it warms up it dies then it should restart after it cools back down. The other issue could be the needle in the carburetor is allowing more gas through than the machine can burn so it dies due to flooding. Letting it sit for a day or so allows the fuel to dissipate and allows the unit to restart
Nov 19, 2014 | Ryobi Recon 4-Cycle H&-Held Gas Blower -...
Ryobi blower stalls when not at full power
there is a gasket right under the prime plug most likely that is bad
Sep 20, 2012 | Ryobi Garden
What is the gas oil ratio of the ryobi leaf blower
Most Ryobi products made in the past 5 years use a 50:1 fuel mix. Check the fuel cap to see if it is listed there. The older Ryobi product used a 32: 1 fuel mix ratio and it was usually listed on the sticker that shows you how to work the choke. If in doubt, go with the 32:1 ratio. The only thing it will cause is premature fouling of the spark plug. Too little oil in the mix will cause premature engine wear.
50:1 is 2.6 ounces of 2 cycle mix to each gallon (U.S.) of gasoline.
32:1 is 4.0 ounces of 2 cycle mix per gallon.
I recommend to use a 2 cycle mix that is specifically designed for lawn equipment and contains fuel stabilizer. The ones with stabilizer will usually be .5 ounces larger.
Nov 30, 2010 | Ryobi Backpack Blower 25.4cc
Wrong kind of gas
It sounds like you used gasoline without oil in a two cycle engine. If so, the repair costs for damage to the engine, caused by running it without lubrication, may very well exceed the $250 to replace the leaf blower. However, I think it is worthwhile to have the repair shop take a look, anyway, before jumping to conclusions. Bring the leaf blower to the shop, explain what you think happened, and they should be able to check out the blower and advise you, without charging for a complete diagnosis.
Mar 27, 2010 | Ryobi Backpack Blower 25.4cc
Mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
Ryobi Backpack Blower 25.4cc Logo
349 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
