My 1998 brivis buffalo, heater clicker that relights is not working
Winter now, so i turned on gas and main switch and relight to on position but the relight that normally makes a clicking sound whilst lighting pilot light clicking sound stopped after a half doz clicks, i've looked at wiring but all seems in contacted, can you help. Regards David.
SOURCE: Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Posted on Aug 03, 2008
  • 13 Answers
SOURCE: Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Posted on Feb 28, 2009
protek480
  • 1714 Answers
SOURCE: pilot light knob stuck
You have to push in on it to move to 'pilot'
Posted on Jul 01, 2009
  • 207 Answers
SOURCE: Brivis Buffalo pilot on but unit not starting, no fan sound?
sounds like ur tstat has gone out
Posted on Feb 26, 2010
  • 12650 Answers
SOURCE: Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
Posted on May 31, 2010
Why won't control knob on water heater turn to off or pilot position so that I can relight
It usually needs to be pushed straight down, or into the valve body, if it is on the side.
Mar 26, 2017 | Water Water Heaters
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Hot water heater went out. Can't relight
check that there is gas in the bottle , the tap is on
check that there is power to the relight system
Oct 25, 2015 | Dutchmen 2011 Coleman 387DQDS
Brivis buffalo 20 problems
Potentially bad pilot valve. clean pilot. then report back.
Jun 12, 2012 | Heating & Cooling
I have a Brivis buffalo 26 unit...the heating is on but it's blowing cold air the pilot doesn't seem to be light but I don't know how to relight it!
Try adjusting your thermostat, contact point possibly melt and welded by electric sparks. Replace thermostat control if contact won't get open.
Sep 02, 2011 | Heating & Cooling
Hi there i recently had another gas appliance installed and the gas was turned off while this work was done, so my hot water service pilot light went out. the guys who did this work didn't relight the...
First turn the dial on the hot water heater to the off position and wait for 5 minutes. Then turn the dial on the water heater to the pilot position. Press in the dial and use a gas grill lighter, long wooden match, or similar device to light the pilot. Once the pilot is lit, continue to hold in the dial for about 1 minute then release and turn the dial to the temperature setting that's comfortable for you.
Dec 11, 2010 | Heating & Cooling
What is the best way to leave a garage heater that will not be used for several days?Gas valve on position,pilot lit,main AC power off ?
Keep the pilot on, it really should not use much gas and are pains to relight sometimes. If you don't have to worry about things freezing, just turn the gas valve to the pilot setting. If freezing is an issue, turn down thermostat to 45 degrees.
Dec 01, 2009 | Dayton Gas Furnace Heater
Heater won't relight or turn back on after the thermostat turns
Verify that your pilot is staying on if you have a pilot.
Some may have electronic ignition.
Oct 01, 2009 | Williams 1403622 Gas Compact Heater
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Heating isn't working, can't find the red button to relight the pilot
Many times the knob to turn the gas on on the valve is also the pilot knob. Turn it to pilot and hold it down while you light the pilot. Hold it for up to a minute and release. If the pilot stays on then turn it to on. If not you need a new thermocouple.
Apr 26, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
