Question about Sony Playstation 3 40GB System Console
When turned on msg says can't start correct hard drive not found
When initially turned on, I get a green wave then a msg says system cannot start correct hard drive not found,,neither dvds nor games can play
    Novelist:
  • Sony Expert
  • 172 Answers
Ok I have the best solution for you you need to do the follow in order to solve this problem ok My name is Juan and I am a ps3' proff so don't worry this is fixable in a portable usb card reader install the newer ps3 update go to sony and in your usb created a folder with the name PS3 in capital letters and inside this folder created another folder with the name UPDATE and download the update on this folder once you have the update ready connect the usb storage device to your ps3 turn the ps3 on and press the PS logo on your ps3 control then on the next screen press STAR and SELECT at the same time and the ps3 is going to start looking for the update follow the instactions and then some model on the next screen you have to press again SELECT and START at the same time but this time hold them for 5 seconds and the update will start after the update finish it will start normally if you have problems doing this call me at 706 529-0579 and ask for juan thanks
Posted on Mar 13, 2009
  • Hugo Guzman
    Hugo Guzman Jan 29, 2014
    juan i have a ps3 fat 40 gb i have change the hard drive form 40 to 80 gb a friend of mine gave me from his old ps3 and it is not working when i do this it is still saiying in a blanck screen wiht white letters can not start appropiate system can not be found
Operating system not found
Unfortunately, Acer PC's do not come with an Official Microsoft Install Disc, however, you should be able to reset the computer to its original factory setting(s), by pressing either F10 or F11 at the initial start-up of the computer, not the start-up screen of the operating system. If this does not work, even though it should as long as you have not altered the HDD internal disc drive to the point to were you would have removed this factory installed reset function. In the event that this setting is not found or available, one other option is to connect an external CD/DVD-ROM Drive to the computers USB port load a copy or an original Microsoft Install Disc into the CD/DVD-ROM Drive. Turn your PC on and at the initial start-up screen of the computer, not the operating system start-up, access the computers bios screen, or boot order screen and adjust the computers settings to boot initially from usb port/external hard drive/CD?DVD-ROM Drive. If your computer allows you to do such, you should be able to re-install the operating system, be it the same or a newer windows version or some other type. NOTE: If you have the know how, you can download free operating system online for free, and creat your own "boot-able" flash drive...
Nov 16, 2012 | Acer Aspire 7741z
My nephew's original xbox will not turn on it just flashes green and orange around the power button
If your system has had an internal system error (three lights) and is now having issues recognizing controllers, remotes, and/or personal music player's, the only currently know solution is to rerun initial setup.
Rerun initial setup
Before trying this, it's highly recommend that you remove all hard drive and memory cards. Once you've removed all hard drives and memory cards, navigate to the systems tab in the main menu and select the "Initial Setup" option. Once you select the option, it will ask you if want to run the initial setup that occurred when you first started your console. Say yes and it will do its thing. When it asks for a memory card/hard drive, just decline and it should be done. You should see the default dashboard screen as confirmation that it did, in fact, rerun initial setup.
Resetting to factory defaults / resetting parental locks (unconfirmed)
This was posted on the xbox-scene forums and might work only with older versions of Xbox 360 dashboard.
Press the following key combination
  • Left Trigger, Right Trigger, X, Y, Left Bumper, Right Bumper, Up, Left Bumper, Left Bumper, X
This should give you a dialogue asking whether or not you want to reset your system to factory default settings.
Reset Xbox 360 video settings
While the Xbox 360 is starting up, hold Y and Right trigger. This will cause the system to reboot and reset the video settings.
Nov 21, 2010 | Microsoft Xbox Console
When my laptop boots up it says operating system not found
Not good. Check your bios for correct drive for boot up, but it sounds like yoru hard drive is not being read....
Oct 26, 2010 | Acer (ACERMOTHERBOARD)
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Primary hard disk drive 0 not found no bootable
Your hard disk is disconnected, or not configured correctly in the CMOS. Go to the BIOS and be sure that the computer recognizes the hard disk. If doesnt happens, check the connectors, and if it doesnt fix your problem, you need a new hard drive.
Jul 18, 2009 | Dell Latitude C640 Notebook
No Oeperating system found
it is possible you have a cd in your cd-rom or a usb drive in your usb port that is trying to load first.
take those out, see if that helps.
if not, it possible you have a corrupted boot sector.
check the hard drive for errors.
thanks
Apr 25, 2009 | Computers & Internet
Turn on but nothing there
Turn it on and push the output connector in the back, just move it a little in and out could be a bad connection.
Mar 29, 2009 | Sony PlayStation® 3 (60 GB) Console
My playstation 3; the startup screan appears that says sony computer entertanment then vanisnes but the wave stays,the waves keep moveing but nothing else ?
Take out hard drive...start system...turn off system...place hard drive back in...start system but do not release finger...you will hear 1 beep then 2....after second you will want to realease..multiple options are given...choose rebuild hard drive...screw sony they wanted to charge me...i figured it out myself...oh and screw you sony for not telling us its all about the dollar...
Feb 18, 2009 | Sony PlayStation® 3 (60 GB) Console
Error msg cannot start correct harddrive not found
Your hard drive has died. You must replace it. Get any size SATA 2.5" notebook hard drive replacement and install it. I have seen this issue plenty of times. Usually on the old 40GB systems.
Feb 11, 2009 | Sony Playstation 3 (PS3) Console
Open Questions:
Sony Playstation 3 40GB System Console Logo
214 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
