SOURCE: SONY 62 LCD GRAND VEGA HD TV
A three flash means you have not seated the lamp cover correctly. Try recolsing and relatching the lamp cover
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
SOURCE: red led flashes. when i try to turn tv on it shuts
There should be a number of flashes that you can count. This is an error code. It will flash a number of times and stop. Again, Flash a number of times and stop. Contact a repair shop that is familiar with panasonic and have them to check it out.
SOURCE: Morning, My Panasonic Viera
Either there is problem in your power supply or main board. There are many SMPS on the power supply board. First check the voltages coming out of the power supply & supplying to the main board. The voltages are printed on the power supply board. The top one is power supply & bottom one is main board.
sonsunny
