Question about Apple iPod nano
IPod nano is dead
My less than one year old iPod just stopped working. is it trash, or can it be fixed?
  • 342 Answers
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on May 19, 2009
Can not restore ipod nano because it says it is busy. Have tried all the suggestions on the websites and chat rooms. Have old ipod nano and mac book with snow leapord
Unfortunately the Ipod may be beyond repair. Ipods are only built to last 3-5 years, and after said amount of time, they start to lose their ability to work. Your best bet is probably bringing it to an apple store, if they cant/wont fix it, then minimally you will get 10% off of the purchase of a new ipod.
Aug 03, 2011 | Apple iPod nano
My nano wont charge or display anything ever since the screen went white and displayed a triangle with unhappy face. what can i do to fix my poorly nano?
Maybe it's just having a bad day. Ipods can be cranky too!
But seriously, Try holding down the center button and the play button at the same time until a white apple appears.
If this doesnt work check your waranty. If it's less than a year old you should be good to go. Trade it in for a refurb - if it works better than what you have, you're good to go.
If it still doesn't work... the only thing I can suggest is to visit an Apple store.
Please give me a good rating if this helped!
Nov 19, 2009 | Apple iPod nano
Nano dead. Will not turn on. It was fully charged.
It's broken. Google "iPod repairs" in your country and they might be able to replace it. Otherwise you can get an exchange unit from Apple. Take it to your nearest Authorised Apple Service Centre and they will get it exchanged in a couple of days. Unfortunately this might cost almost as much as a new one.
Nov 03, 2009 | Apple iPod nano
Ipod nano firmare problem
if the firmware is damaged, then it's as simple as pluging it into your computer and on the ipod 'menu' there's a button below "check for new version"
click on that, it will reset your firmware
if that doesn't work, take it to apple
if they can't fix it, trash that old stupid thing, it's time to get a new ipod
Aug 13, 2009 | Apple iPod nano
My ipod nano isn't working
This is happening to my daughter's dock/clock too. It seems to have a short in the connection. If I jiggle it around I can get it to connect for a minute. Less than a year old, wish the warrenty was longer than just 90-days. Anyone know how to fix this problem?
Aug 05, 2009 | Starlite Next Play Clock Radio with iPod...
60gb Apple Ipod is dead
check out this link,, it should help you re-boot your ipod :)
it worked for me,, sooo hopefully it would work for you
i hope this has helped you
Jessica xx
Mar 18, 2009 | Apple iPod MA446LL/A MP3 Player
IPod not working in my music dock
Hi Natalie
Sounds like you're having logic board troubles. You need to take it to an ipod repair specialist to take a look at it. Sorry to bring the bad news. Chances are it's not a simple repair and will need a new logic board and they're not cheap:
http://cgi.ebay.com.au/Apple-iPod-Nano-3rd-Gen-Logic-Main-Board-Motherboad-4GB_W0QQitemZ110290080297QQcmdZViewItemQQptZOther_MP3_Players?hash=item110290080297&_trksid=p3286.m63.l1177
If it's still less than a year old take it back to an apple store asap for a free replacement.
All the best
Sean
PiDigital
Dec 29, 2008 | Apple iPod nano
Ipod problems
try your hardest
Aug 05, 2008 | Apple iPod nano
Connection problem
first try using different cables just to make sure it's not the cable that's the problem.
if the problem still persists then it might be the ipod itself, and since it's 2 years old you'll probably have to pay to get it fixed, it's probably cheaper to just get a new ipod.
Mar 04, 2008 | Apple iPod nano
Apple iPod nano Logo
129 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
