Question about Craftsman Garden
My craftsman 21" lawnmower model #247.37037 quit running after hitting a block of wood with blade and will not restart. what do i need to do to fix it?
My mower is 1 year old.A couple of times it almost tried to start when pulling starter cord.The blade turns when pulling starter cord. The spark plug looks good, I just cleaned it and regapped it. The air filter is clean. It was running fine before hitting piece of wood.
5 Suggested Answers
SOURCE: Troybilt self-propelled mower - model 556 won't start
pipe from carb to engine broken. couldn't tell until covers & fuel tank removed. also part of deck holding engine came apart on mine. due to excessive vibration???
Posted on Mar 16, 2010
miket756
  • 2702 Answers
SOURCE: 8 year old Eagle I Craftsman 6.5 starts and quits? Help!
it sounds like a gumed up carb strip the carb and clean out all the running jets with carb cleaner,,,dont go poking wire into the jets you will only distroy them,,,also check that the air cleaner is clear if its cloged up the engine cant breeth and wont rev up and it will be running very ritch as well,,,check you have good flow of fule from the fule tank,,,winter takes its toll on garden tools that are stood up most of the time
Posted on Jul 10, 2010
dan5268
  • 542 Answers
SOURCE: My craftsman push mower won't start, I changed the spark plug, I need to download the owners manual for help. The model @ is 917.373981
Here is the manual for your Craftsman
Posted on Apr 11, 2012
  • 16 Answers
SOURCE: I Have a push mower
Sounds like the blade maybe bent, you should either try to straighten it out or replace
Posted on May 05, 2012
Where is the blade lock for CRAFTSMAN 315.10951
quite possibly there is none . most people use a block of wood held against the blade.
Aug 16, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
I have a brand new craftsman 190cc lawnmower and the pull cord will not pull out
If it's new sometimes the manufacture puts a safety block to hold it from moving during transit. Check for this. See if the blade will turn and if not see if there is a seized area. Is the blade jammed against something.
Jun 30, 2014 | Craftsman Garden
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Lawnmower blade won't rotate
not sure i can help but you could have a lot of problems your engine is locked up or you have bent your crankshaft or your pull rope assembly is in need of repair . or it has a bent blade and it it hitting the deck . or you have a broke connecting rod .
Nov 04, 2013 | Craftsman 675 Torque 190cc 21" Briggs ...
Removing blade
place a block of wood between the blade and the mower body to hold the blade from turning
Aug 09, 2012 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Change blade on gas lawnmower
varies slightly as u didnt give model, i run front wheels onto car ramps and block rear wheels, then in middle of blade is a large bolt hold blade with leather glove and unscrew, put new one on and tighten,
Jun 09, 2012 | Craftsman Garden
My Craftsman Series 550 Lawnmower was working fine and I decided to check and clean the airfilter and carburetor. When I tried to restart the pull cord is stuck and won't allow me to pull it. I have...
i suggest you pull the housing off for the pull cord and see if it pulling fine if it does see if the brake is of on the motor i would bet the brake is not releasing
Jul 17, 2017 | Craftsman Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Zts has no Power when Blades Engaged
check your blades to make sure that they are not hitting the deck,, this would cause the knocking sound
Aug 19, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Garden Logo
199 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
