Question about HP LaserJet 3030 All-In-One Printer
Doc. feeder jam, after paper removed completely
After completely removing paper from top feeder jam, the screen continues to display 'Doc. feeder jam' and does not reset after pressing cancel button or enter. It will not reset itself even when turned off and on.
  • darryl_duet Mar 12, 2009
    when i removed the paper there were no pieces missing, and i have opened and closed feeder cover, any other suggestions
    Top Expert:
  • HP Master
  • 11,573 Answers
Posted on Aug 13, 2016
Have you physically open the Document feeder cover on the left and made sure that there are no little pieces of paper here? Plus opening this section is the only way to reset an ADF jam.
Posted on Mar 12, 2009
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
My printer displays "doc feeder jam". I have
Why dont you try remove the drum and cartridge, just try it
Jan 07, 2011 | HP LaserJet 2840 Printer
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
    If paper is jammed, a Paper jam message will appear on the control panel display.
    Follow these steps to clear the jam:
    1. Gently pull any jammed paper out of the output tray or sheet feeder.
    2. If the paper is stuck inside, turn off the Epson Stylus CX.
    3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
      alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
    If paper jams inside the Automatic Document Feeder, clear the jam as follows:
    1. Open the Automatic Document Feeder cover and remove any jammed paper.
    2. If necessary, lift the document cover and remove any paper that has jammed inside.
    3. Press OK to clear any messages on the display screen.
    Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    Stylus CX9400 Photo Printer: paper jammed inside printer...
    May 18, 2010 | Epson Stylus CX9400 Photo Printer
    The printer is constantly sending a message- 'paper jam'
    HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
    Issue
    During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
    Solution
    Use the following instructions to clear a paper jam from the product:
    Step one: Check for and remove any loose paper from the In tray
    Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
    CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
    Step two: Clear the jam from the back of the printer
    Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
    Remove the rear access door to clear the paper jam
    1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
    Figure 1: Removing the rear access door
    Rear access door
    2. Gently pull the jammed paper out of the rollers.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
    3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
    Remove the two-sided printing accessory to clear the paper jam
    1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
    Figure 2: Removing the two-sided printing accessory
    2. Gently remove any jammed paper.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
    3. Press the button on top of the two-sided printing accessory to open the door.
    Figure 3: Opening the two-sided printing accessory door
    4. Gently pull the jammed paper out of the rollers.
    5. Close the accessory door.
    6. Reinstall the two-sided printing accessory.
    Step three: Clear the jam from the automatic document feeder (ADF)
    1. Remove the document feeder tray from the product by gently pulling it.
    2. Lift the cover of the automatic document feeder by pulling it outward.
    Figure 4: Lifting the cover of the automatic document feeder
    Automatic document feeder (ADF) door
    3. Gently pull the jammed paper out of the rollers.
    WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
    4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
    Step four: Verify that the print carriage can move freely
    Follow these steps to try to move the print carriage.
    CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
    1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
    You may have to reach through the output paper tray to access the print carriage.
    5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6. Press the On button to turn on the product.
    Step five: Reload and test the printer
    After you have removed the jammed paper, make sure the product is still functioning properly.
    1. Reload the product with plain paper.
    2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
    Step six: Service the printer
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Dec 30, 2009 | HP DeskJet 3745 Printer
    NP6050 false paper jam at doc feeder
    When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
    Dec 12, 2008 | Canon NP 6050 Copier
    Paper jam in the automatic document feeder
    I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
    Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
    Document feeder
    Does the adf show a paper jam? If so remove it or look for some thing blocking the paper path and remove it. Also try to turn off the copier and disreconnect the doc feeder and turn it back on and see what happens.
    Feb 19, 2008 | Minolta Di3510f Bizhub Copier
    HP LaserJet 3030 All-In-One Printer Logo
    858 people viewed this question
    Seeker5211
    Seeker5211
