Question about Delta 16955-SSSD Stainless Steel Victorian Single Handle Kitchen 16955-SSSD
Swing arm too loose
The swing arm on my 19655 ssd swings to freely, would like more resistance.
  • gag11 Mar 11, 2009
    I should add that the faucet is brand new its not worn.
    President:
  • 2,692 Answers
What I have doen in the past is to take the compression nut off. Wrap teflon plumbing thread tape around and between the two o rings and tinghened the compression nut back down,tightening the worn swing arm joint.
Posted on Mar 11, 2009
How do I remove the race out of my polaris magnum 325 swing arm ? Should I buy a slide hammer?
Do you have access to a press? ... ask around.. or take it to a friend at an automotive shop.. you will save yourself some grief..
Oct 26, 2016 | Polaris 2004 Magnum 330 4X4
Loose swinging arm
Lay the bike on its side. Superglue the bush to the swing arm. Lay the bike over the other way and repeat. Do not glue the bush to the shaft.
Nov 27, 2014 | 2009 Harley Davidson FXDC Dyna Super Glide...
Loose clutch cable
Either the cable is sticky inside and not returning properly or the arm the cable operates on the deck with tensioning idler is not swinging back and forth freely.
Feb 01, 2012 | Craftsman Garden
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
I have aligned the chain (every couple of months I have to tighten the chain , does it stretch that much!) and when I'm driving the chain noise is louder than the engine . Is this normal??
Raise the rear wheel off of the ground. Spin the rear wheel by hand while running the chain over your hand (wear a surgical glove or use a rag). If the chain gets tight and then loose it has stretched and needs to be replaced. If it is an older Honda (70's), unbolt the rear shocks and see if the swing arm moves from side to side. If this is the case you also need new swing arm bushings. Another sign that the swing arm bushings are bad is if the chain is banging against the swing arm while you are driving down the road.
Jul 10, 2011 | Honda CB 350 F1 Motorcycles
Resr end of bike seems to twitch at times could it be swingarm
Things to check. Is the chain adjusted correctly and is the rear axle tight. With the rear wheel off the ground can the wheel be rocked around on the axle (Are there bad wheel bearings?). If you still have the problem after these checks, raise the rear wheel off the ground,take off the wheel, unbolt the shock (check mounting bolts for looseness), grab the rear swing arm to see if it moves or wiggles at the pivot points. You probably have bad swing arm bearings. If the swing arm bearings are bad you will probably have to change both bearings and the long inner bushing to fix the problem.
Mar 19, 2011 | 1989 Yamaha XJ 600
Have a DC25, I can not return the handle to the upright position. Nothing appears to be broken
Occasionally, customers have problems locking their Dyson vacuum in the upright position. This is a minor problem common with the Dyson DC07 and DC14 series and can easily be fixed by the customer. This page will show how to fix this problem. Although we show a Dyson DC14 Animal on this page, these instructions will work on any Dyson vacuum in the DC07 and DC14 series.
During shipping, moving parts on a Dyson vacuum can shift in position. One of these parts is a swinging arm in the base of the unit. This arm holds a removable elbow pipe in the vacuum's air passage. This arm can move out of the way so that you can clear out a blockage in the air passage. When this arm is out of position, the vacuum will not lock in the upright position. Fig. 1 Shows the base of a Dyson DC14 Animal locked upright. The red arrow points to the swinging arm. Fig. 2 shows the vacuum with the swing arm out of position. Since the swing arm is lower than it should be, it doesn't line up with the tab on the main body indicated by the red arrow.
Lean the handle of your Dyson all the way back and locate the black button on the right side of the vacuum indicated by the red arrow in Fig. 3.. Press the button down and hold it to unlock the swing arm.
While holding down the black button, pull the swinging arm (Shaded red in Fig. 4) all the way up. Fig. 5 shows the swinging arm in the correct position. Release the black button to lock the swing arm back in place.
The vacuum can now lock in the upright position as shown in Fig. 6. Note how the tab on the swinging arm overlaps the tab on the main body..
dcramer531_17.jpgdcramer531_18.jpgdcramer531_19.jpgdcramer531_20.jpgdcramer531_21.jpgdcramer531_22.jpg
Dec 11, 2010 | Dyson DC25 All Floors Bagless Upright...
When should the rear swing arm and driveshaft be serviced?
if there is any play in the swing arm its time to service it and fit new bearings but any time is a good time to grees it up as for the drive shaft this needs looking at every year or so again its a grees up pull off the shaft and clean off all the old grees first the shaft must slid freely on the splines
Apr 14, 2010 | 2004 kawasaki VN 1500 Vulcan Classic
Drive chain adjustment
To adjust the chain you need to make sure you make the adjustment with the swing arm parallel to the ground, (this is the tightest point in the arc of the swing arm moving rotation), at that point you want to be able to put two finger between the chain and the swing arm at the swing arm pivot bolt. This will insure proper adjustment every time. The best thing to do is have somebody sti on the bike off the stand to make sure the swing arm is at its MAXIMUM arc, otherwise you stand a significant chance of over tightening it and this can and WILL cause SERIOUS damage to your engine. You will rip the output shaft bearings out of the center cases.
You also want too make sure you have proper wheel alignment as well. There are marks on the rear of the swing arm for adjusting the chain, make sure you have the marks on the adjusters in the same location on BOTH sides of the swing arm.
Please let me know if you need further assistance.
Regards,
RSelvy
Dec 17, 2008 | 2005 Suzuki RM-Z 250
Wurlitzer one more time 1015 flashign #8
It's the 'duck bill' bracket on the shaft near the gear box. On the others side of the white gears at the base of the tone arm. There's a white bracket that dips and clicks a microswitch when the gripper arm is over the carousel. It's come loose. Press it with your finger when the gripper arm is over the carousel and it will stop. Tighten it in that position..
Dave. The Jukebox Doctor.
Dec 29, 2007 | Wurlitzer Jukebox 1015 One More Time...
Delta 16955-SSSD Stainless Steel Victorian Single Handle Kitchen 16955-SSSD Logo
166 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
