Question about Panasonic AG-520G 20" TV/VCR
Remote won't communicate with television
Have tried universal remotes but still won't work with tv/don't think the problem is in the remote controllers. think it is within the set itself.
    Problem Solver:
  • 7 Answers
The sensor for these Panasonic tvs along with certain Toshiba models tend to have the problem with the sets sensor going out. But if you are using a universal remote because you do not have the original, then most likely you will need to use the vcr control codes to program the tv. but if the original doesnt work either. your insticts are probably right. There is one last trick if you do have the original remote that u can try. I've had this work for me several times on service calls. With the batteries removed. Press every single button on the remote once. make sure you do this nice and slow making sure you are pressing the button down . if its a toggle button or rocker button like most volume or channel up down buttons(meanning that physically the is one button but depending on what part of button you press it does something differemt) well treat these as seperate buttons. Also if the remote has any switches on it. Like vcr/tv switch or vcr 1 vcr 2 etc. Then switch to other position and repeat the process of pressing all buttons once again. (remote does not have too be pointed at tv for obvious reasons) Now replace the batteries and have fingers crossed. Good luck.
Posted on Apr 26, 2010
My RCA tv won't work without a remote, and I can't seem to reset since I don't have a menu button
Hello
If your TV has no menu button on its front panel, there is no other way than buying a universal or original remote control to this set.
Mar 04, 2012 | RCA Televison & Video
Universal remote (GE 24116) that i purchased to replace the lost remove control for my sanyo 42 inch tv won't work. the arrow buttons don't work in the menu which is the only reason I bought the...
Hi, You need a code to match with your TV remote. The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
Sep 09, 2011 | Sanyo 42 in. LCD TV
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
Why does'nt my vizio tv works with universal remotes
U follow the universal tv remote operation of manual book directions correctly?Yes,have u tries all those tv universal codes that was given to u for ur tv model and make?Yes.Than the tv maual IR sensor board on the tv could be dead,tries all those manual buttons on the tv side bazel frame,if all of it tv manual buttons work,properly the universal tv remote to complicated for u to operate.Return the thing.Try website like Remote.com to buy the tv original remote,than u don't ever care about universal codes ever again.
Jul 12, 2011 | Vizio L37 Television
My remote wont work on my grundig gu15wdt/gu15wdpcx, have tried changing the batteries and it still doesnt work, where can i get a new one?
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Lastly, please don't by a remote with confirming it is a remote problem. You have to be sure before thinking of a battery replacement.
Regards.
Jun 09, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
I lost my remote control tv-dvd thrutech model t2000d .what is code i can use universal remote conrol
U tries those codes that came with ur universal remote owner manual codes for ur tv model already.Those codes don't work for ur tv.Return the universal remote,because any codes people give will not work either.Try website like Remotes.com to buy the tv original remote.
Jun 09, 2011 | TruTech T2000D TV
My panasonic tv dvd vvcr combo remte rplacement i have tryed universals remotes but they don't work
Return the universal remote,if all ur tv universal codes of ur tv on the owner manual,don't work.Try website like Remotes.com to buy the tv original remote or very close capatible to it.Yes,it cost double even tripple the prices of any niversal remotes,but these remotes are 100% it will work with ur tv,because it the same or compatible as a orginal remote would.
May 31, 2011 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Broken Remote how do I get a replacement or get it to work with a dvd player
Try website like Remotes.com to buy the tv original remote.Little more exspensive than those universal remotes.Don't tries this tv with those universal remotes,it will not work or have universal codes for this tv.This tv was a specially manifacture for the Disney Corporation only for briefly period of time only by an small un known electronic Corporation for the late 90 Aminations cartoons movies fads only.
May 27, 2011 | Disney 13" TV
Remote does not work!
I have a universal remote and I am trying to communicate with my Magnavox TV but I cannot communicate.
Jun 25, 2009 | Sharp 21" Multi System Stereo TV
Remote control volume
Reset the TV. Unplug it, wait 1minute and replug it. Did it work?
Aug 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Panasonic AG-520G 20" TV/VCR Logo
156 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
