Question about Toshiba 32gb Usb Flash Memory Stick Drive U2p Usb
I purchased a new Toshiba USB flash memory u2J001(A) and it requires a password that i do not have can u help me
After factory resetting of nokia300 memory card has blocked
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Sep 15, 2012 | SanDisk 1GB microSD Memory Card
Tip
Forgot Toshiba Windows Login Password? How to Reset it?
<span> <p><img src="toshiba.jpg" />Security-conscious or just want to ensure your files are private? You can prevent others from using your unattended Windows PC by creating a password to use Windows or quite your screen saver.<br />Well, everything has two sides to. On one hand we can ensure the safe of the Toshiba computer privacy or confidential files; on the other hand, we are always bothered how to crack or reset<a href="http://www.passwordunlocker.com/knowledge/forgot-windows-7-password.html"><span> </span>forgotten Windows password</a>. Today, we will focus on how to reset Toshiba password and regain your access into the Toshiba.<br />Of course, if you input"<a href="http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html">how to reset Toshiba password</a>", you will find various related info for this. Indeed, if you forgot Toshiba Windows password, you can reset it by taking a Windows password hint, a password reset disk, a system Installation Disc which is provided by Microsoft or just reinstall your Toshiba laptop. But have you ever realized that these methods can make sense only when they are under some conditions.<br />From now on you do not need to worry about these problems any more. According to our experience, we would like to recommend you another easier and practical solution--- a third party program. Here we also download<span> </span><b>Windows Password Unlocker</b><span> </span>for instance, which is well-recognized and wide-used shareware for Windows password recovery. Now, follow the step-to-step guides and reset Toshiba password within a few minutes.<br /> <ul> <li><b>Requirement:</b><span> </span>A bootable CD/DVD or USB flash drive</li> <li><b>Time:</b><span> </span>within 5 minutes</li> <li><b>Recovery Rate:</b><span> </span>100%</li></ul><b>Step 1:<span> </span></b>Go to<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker</a></b><span> </span>official site to Download and install Windows Password Unlocker any available PC.<br /><b>Step 2:</b><span> </span>After installation the program, insert a CD/DVD or USB flash drive for burning an ISO image file.<br /><b>Step 3:</b><span> </span>Set your locked Toshiba PC boot from CD ROM or USB with the password reset disk<br /><b>Step 4:</b><span> </span>Reset Toshiba Windows Password in minutes. After restart Toshiba laptop you can login straightly without a password required.<br />So, is it more convenient to<span> </span><b>reset forgotten Toshiba password</b><span> </span>with this Windows password recovery tool? Well, this program applies to all the popular OS like Windows 7/XP/Vista/2000 and Windows Server 2003/2008.<br /></span>
on Apr 25, 2011 | Computers & Internet
Tip
Toshiba Reset Password for I Forgot Toshiba Laptop Password
"I need Toshiba password reset! How do I reset Toshiba laptop? I would be appreciated if you help me Toshiba password recovery, etc." Well, so frequently to meet these problems in our lives. Today, we together share some ways to reset Toshiba password.
Solution1: Toshiba recovery disks help reset lost password
It only works if we created the recovery disks or CD before we forgot the password. The following listed are the steps to reset disk for Toshiba Windows 7 recovery:
a. Start PC, log on Windows 7 and insert an USB flash drive into the driver.
b. Start -> Control Panel -> User Accounts and Family Safety -> User Accounts -> Create a password reset disk.
c. In welcome screen click "Next" and select the inserted USB flash drive, click "Next".
d. Input the login password in the password field and click "Next". When progress indicator shows 100% complete, click Finish to exit. Remove the USB driver from PC.
The method is similar to create a Toshiba recovery CD. Now, the Toshiba Windows 7 password recovery disk is ok. Put it in a safe place for people may use it to reset your password.
Steps to recover password with created Toshiba password reset disk:
e. Click "Reset Password" in the Windows 7 logon window,
f. Insert the created Toshiba recovery USB disk into the USB driver interface, and click "Reset password" to open Password Reset Wizard. Click "Next" to continue.
g. Choose this USB disk recovery Toshiba from the drop down box. Click "Next" to continue.
h. Input a new password and re-input it again to confirm. Click "Next" and then "Finish" to close the wizard.
Solution2: Reset Toshiba laptop by accounts with administrator rights
If there is default or built-in admin account or other accounts with administrator privileges and rights, we can use it for Toshiba password bypass. Take Toshiba XP recovery as example:
A. Boot system from Safe Mode by pressing F8 when PC stars.
B. Access PC with the available account with administrator rights and privileges.
C. Start - Local Users and Groups - lusrmgr.msc in the Search box - ENTER - Local Users and Groups - choose Users.
D. Right click the account with unlocked password, select Set Password and then input and confirm the new password.
Solution3: Reset Toshiba password with burned ISO image file
We can burn an .iso image file into a bootable USB disk or CD/DVD and reset the forgotten password easily and quickly. Take one of the most popular Windows password reset tool - Ainorsoft Windows Password Recovery as example:
a. Download the program from an accessible PC;
b. Burn its .iso file to a blank CD/DVD or USB disk;
c. Bypass the lost Toshiba password with the burned CD/DVD on the locked PC.
Things will not be tricky if we know the methods for Toshiba password reset once we forgot Toshiba laptop password! Please also remember to share them with your friends!
source: http://windowspasswordrecovery.net/article/toshiba-password-reset.html
on Mar 16, 2011 | Toshiba Satellite Pro L300 Notebook
Plz help me ......... i dono rmmbr my memory card password.... and it contains very much important data........ and my set is nokia 7230 which does not support .sis file.
>purchase a memory card reader
> insert the memory card in it
> connect memory card reader with computer USB port
> copy all important documents to your computer
Jan 31, 2011 | Kingston 4GB Secure Digital High Capacity...
My phone memory is locked, how do i open it?
Hi, incase u do not require the data in the memory card then simple insert the card into ur computer using a usb card reader and format the whole card the password should get erased along with it and ur card should start working again
Jun 11, 2009 | SanDisk 1GB microSD Memory Card
I dont know were to insert memoey stick from psp into my pc
your memory stick should have came with its own card reader, which is a small device that the card fits into, on the end of that device is a plug to plug into any of you USB ports on your laptop.. If it did not come with a reader device you will have to purchase one.
Hope this helps
Apr 16, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Requires a password
There is a locking tab on the side of the card, slide it off of lock.
Apr 01, 2009 | SanDisk 2GB microSD Memory Card
My Toshiba laptop all of a sudden is asking for a BIOS password. I never enable that feature and all the backdoor passwords does not work. I did everything short of flashing the BIOS. I was wondering if...
woops - sounds like someone put a mischievous password in there - sadly to remove a password from a toshiba requires a special 'dongle' to be placed in the serial port - even reflashing may not remove it.Most toshiba service centres will remove this for you on providing proof of ownership - otherwise do a quick search on ebay for the dongle..
cheers
Nov 19, 2008 | Toshiba Computers & Internet
Usb drive
flash drives do not have passwords, unless u have purchased password protected ones. pls checkup with your pc/cmera or mobile.
may be the flash is defective and all companies give replacement for this problem
Apr 19, 2008 | Electronics - Others
L15 lost usb ports
Hi
I am Toshiba Specialist. I have encountered similar issues. Best and most effective solution is Flashing the BIOS for newer version. All you need to go Toshiba's support website http://support.toshiba.com and locate your exact model and go to download section get the latest BIOS. There will be 3 methods available (FDD/CD/Windows) so you can choose the most convenient method. As you will see the warning BIOS flashing requires extra care like keep the AC power and do not run other aplications during the flashing the BIOS. when flashing complete it will restart the computer and it will resolve the Issue.
Good Luck
Dec 01, 2007 | Toshiba Satellite L25-S119 Notebook
Toshiba 32gb Usb Flash Memory Stick Drive U2p Usb Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
