Question about Horizon Exercise & Fitness
How do i get the incline to work on the t61 treadmill
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
bwinton
  • 83 Answers
SOURCE: Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
  • 34 Answers
SOURCE: will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Posted on May 24, 2010
maxtreadmill
  • 832 Answers
SOURCE: The incline on my proform treadmill is not working
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
Posted on Jul 19, 2010
Stuck in up position. Bought a new incline more and if it goes above 5, it will keep climbing and won't come down.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 24, 2016 | Horizon T61 Treadmill
Incline does not work but incline motor runs for 3 to5 seconds proform415ct
if the motor tries to work but incline does not go up something is jammed on the treadmill or the incline motor is bad
Oct 17, 2014 | Proform 415 CT - Treadmills
How to disable the beeping on a Horizon T61??
RUN the software calibration for easy diagnose, troubleshooting, and fix it.
However read your owner manual and follow the instruction in troubleshooting section, how to disable the beep.
Test the speed sensor+ reed switch, for open or defective, CLEAN it and tight any plug or connector.
see the block diagram
God bless you
Nov 17, 2012 | Horizon T61 Treadmill
I have an Epic t60. The incline stopped working. I was in the midst of going from flat incline to full and then back down again when it stopped. The incline numbers now register on the display, but it...
Try to recalibrate the incline. Start the machine running, press the incline up button, then pull the safety key off. Release the incline up button and replace the safety key. The treadmill should go to maximum incline then minimum. after calibration is completed, retry the treadmill operation.
Jan 11, 2011 | Epic Overstock T60 Treadmill Treadmills
Apr 28, 2010 | Life Fitness 9000 Next Generation...
Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
Treadmill not working properly. Incline keeps slipping.
there is a plastic spacer at the rack area on the incline mtr- this white plastic spacer has broken, only recourse u have is to unplug the white wire on incline mtr, and never have a incline, or replace incline mtr when you find out how much the mtr is you might want to walk with out incline- if you was in my area, I have them cheaper
Jan 07, 2010 | Proform Quick Burn Pro Treadmill with 12...
Will my ifit treadmill card work in an incline
Nov 29, 2009 | Proform Quick Burn Pro Treadmill with 12...
My console does not allow me to change the incline, speed, etc. The control panel does not acknowledge the buttons pushed. I've turned it off and on.
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Sep 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Exercise & Fitness Logo
24 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
