Question about Nokia 5233 Cell Phone
No signal signal jumper
    Master:
  • 368 Answers
Hello:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Apr 20, 2013
Left turn signal dos not work on outside
What is year--make--model?
If the right side works fine, have to check turn signal switch and wiring. Sometimes, at the turn signal switch, you can use a jumper wire on the proper wire terminals and make them turn signals dance. The jumper just bypasses the switch, so if it works, I think the switch is the problem.
Mar 17, 2016 | Cars & Trucks
My turn signal quit working i checked the fuses and the bulbs and put a new turn signal switch in it and the turn signals still aren't working what else could it be
Usually when you get at the turn switch, you can use a jumper wire to bypass the turn switch and make the turn signals dance. If they won't work with the jumper, the problem isn't the turn switch. Maybe a problem with flasher or wiring issue in steering column?
Did you check for voltage at the turn fuse? Goes hot with the key on. Use a test light to check for voltage.
Jul 12, 2015 | 1992 Chevrolet Lumina
WHAT DOES RH,RC,W ,Y,G MEAN
These are the identifiers for thermostat wiring terminals / wires.
Wire Thermostat
Apr 07, 2015 | Heating & Cooling
Horn doesn't work
remove grill ck horns with jumper wires ck plug for power, if horns work .if horns dont work with jumpers replace . if no power ck fuse if good relay for signal and power if no signal when horn pushed either horn switch in airbag ,or cable reel witch need cked with special srs tools .
Aug 04, 2012 | 2005 Chevrolet Silverado 1500 2WD
1981 ford ranger pick up turn signals only work when truck is off, but when running the turn signals wont work how can i fix this?
could be a bad ground. an easy way to check would be to connect jumper cable from engine to cab, and also connect jumper cable from engine to frame. start truck turn on turn signal, if they work then install new bonding straps.
Sep 21, 2011 | 1981 Ford F 150
I am unable to send a signal via aux 6 from a channel to ONLY the K sub. The only way I get signal is if I raise the channel fader but then the signal goes to the house L/R mains as well. How do I send a...
It appears that AUX6 is default factory strapped as POST FADER. If you want to change that you will have to disconnect jumper L to A for all channels you want the AUX to be pre-fader and instead connect K to S for the option jumpers. I don't know if this requires soldering or whether they are push on jumpers. These should be available in the back cover. In ADDITION you will have to run the switched pre/post fader switch in the PRE position which will make ALL AUX's that are strapped this way PRE FADER.
Jul 09, 2011 | Allen & Heath Mix Wizard Wz3 16:2...
I need a nokia 7360 signal jumper diagram, pls. help me
Below is signal jumper diagram for nokia 7360 ..
Mar 22, 2011 | Nokia Cell Phones
Pa jumper pin no of nokia2626
Nokia 2626 Signal No Network repairing solution.Nokia 2626 Signal No Network Mobile Repair diagram pictures Service Tips and Tricks.Make Jumpers as shown in diagram or replace the shown components .
How to short Nokia 2626 PA.jumper Pa nokia 2626. here is a diagram that is showing how to jumper and short P.A of nokia 2626. it is used to check that mobile is getting signals or not. if signals are to low with jumper change the P.A
Jan 21, 2011 | Nokia 2626 Mobile Phone
Signalminder Problem
Do you have the jumper switches set correctly? I can't think of anything else, unless you got a defective one. There's nothing to do but set the jumpers and plug it in.
Nov 10, 2008 | 2007 Triumph Bonneville T100
Signal board jumper wires?
Hard wire jumpers feeding voltage to convergence circuitry located between board edge and current limiting resistors & near STK IC's.................HTH........................T.
Most H-line Toshiba's have them......
Aug 21, 2008 | Toshiba 43H71 43" Rear Projection...
Nokia 5233 Cell Phone Logo
64 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
