Question about Dryers
Attic fan won't turn off
The fan is easily accessible in our attic. It has a little thermostat with temperature settings and it is set for 90 degrees. The fan goes on automatically on a hot afternoon but then won't go off even after dark when it has cooled down nicely. I have to climb up there and turn the thermostat up to make it switch off. Once off, I can set it back at 90 and the fan doesn't come back on until the next hot afternoon.
dragonsthatk
  • 547 Answers
SOURCE: lint bypassing lint filter and water in vent transition hose
your hose is to long you should vent it stright out wall if you can't you can buy a small inside vent kit it take so long to dry becuase it's not exsusted proper
Posted on Feb 12, 2009
localwonder
  • 6784 Answers
SOURCE: Clothes won't dry
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Posted on Jun 02, 2009
  • 1114 Answers
SOURCE: Combo lite/vent fan/nite light affected by heat?
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
Posted on Jul 20, 2009
mgprice
  • 744 Answers
SOURCE: my dryer stays hot
Hello, I'm going to assume this is a Electric dryer since you did not mention :) Ok your problem is with your heating coil. Basically what has happend is the coil has broken and the end that is wired strait to the electric supply is touching the chassis of where the heater is located, You should replace the heating coil and this will solve your problem :) You have a nice day and if there is anything else i can help you with please feel free to comment again. Thanks for using Fixya!! Mike
Posted on Jul 23, 2009
  • 28 Answers
SOURCE: Kenmore Dryer only dries on high heat. Even though
Helo
Try running your dry on no heat, If it still heats you need a timer. Make sure your vent is clear .
Posted on Sep 13, 2010
Testimonial: "I rec'd a response the next day! It will give my husband, who's quite handy, a place to start in solving our dryer woes. Thanks so much!"
faulty thermostat switch
Jul 15, 2017 | Broan-NuTone Dryers
Wiring a master flow PT6 thermostat to attic fan
I had a roofer install Master Flow PRO 3 and he did the initial wiring incorrectly. The black wire pairs were incorrectly connected and caused the fan to run 24-hours. I switched the black wires pairings and the fan shuts off if less than 100-degrees (the setting I chose) and comes on if more than 100-degrees. You may want to be sure that the black wire from the power source is connected to the black wire for the thermostat (black wire nearest the thermostat setting switch and closest to the power source wire). The black wire from the fan motor should be connected to the black wire closest to the fan motor's wire.
Aug 01, 2012 | Cars & Trucks
My newly installed Broan-NuTone attic fan worked fine for two days. Now it wont turn off, even though the temperature has dropped well (40 degrees)below the setting(100 degrees).
Hi. The most likly cause of this type problem is the thermostat. Check the thermostat housing is it hot to the touch, is it close to a heat soarse, suchas, a motor or flu pipe for a water heater. If the thermostat has a adjustable heat range setting try setting it to the lowest setting if this shuts the unit off the calibration of the unit may not be set right. If the unit is new this should be covered under warranty.
Jun 12, 2011 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
Jul 19, 2009 | Broan-NuTone N-8663RP Combination Light...
Concern of fan turning on and off to often
You have to set the thermostat due to the weater at that time. the main time is summer to blow out heat so set it higher to avaoid on and off situations.
Apr 09, 2009 | Dryers
Attic fans
I just fixed a Broan-353 with a similar problem - the fan was short-cycling, turning on and off within a minute or less.
These fans have a thermostat which is designed to turn off 10 degrees below where it's set to turn on. Apparently, one failure mode is this temperature delta stops working I've had this happen twice, each time after about 3 years.
Replacement thermostats are available from Broan for about $30 http://parts.broan-nutone.com/broan/Shop It's a 10 minute repair if you have easy access to the fan.
May 23, 2008 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
Blower in Attic not running
inside unit has fan control relay , either on control board or can be separate ,except for the 24 volt transformer and the t-stat the units operate separately concentrate totally on the inside unit this is where the problem lies
Oct 23, 2007 | Ruud UAMB Air Conditioner
Dryers Logo
657 people viewed this question
Top Dryers Experts
