Question about Broan-NuTone Dryers
Attic fan won't turn off
The fan is easily accessible in our attic. It has a little thermostat with temperature settings and it is set for 90 degrees. The fan goes on automatically on a hot afternoon but then won't go off even after dark when it has cooled down nicely. I have to climb up there and turn the thermostat up to make it switch off. Once off, I can set it back at 90 and the fan doesn't come back on until the next hot afternoon.
    Top Expert:
  • Broan-NuTone Master
  • 12,113 Answers
Faulty thermostat switch
Posted on Jul 15, 2017
3 Suggested Answers
  • 1114 Answers
SOURCE: Combo lite/vent fan/nite light affected by heat?
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
Posted on Jul 20, 2009
BOSS5353
  • 12 Answers
SOURCE: My newly installed Broan-NuTone attic
Hi. The most likly cause of this type problem is the thermostat. Check the thermostat housing is it hot to the touch, is it close to a heat soarse, suchas, a motor or flu pipe for a water heater. If the thermostat has a adjustable heat range setting try setting it to the lowest setting if this shuts the unit off the calibration of the unit may not be set right. If the unit is new this should be covered under warranty.
Posted on Jun 12, 2011
Wiring a master flow PT6 thermostat to attic fan
I had a roofer install Master Flow PRO 3 and he did the initial wiring incorrectly. The black wire pairs were incorrectly connected and caused the fan to run 24-hours. I switched the black wires pairings and the fan shuts off if less than 100-degrees (the setting I chose) and comes on if more than 100-degrees. You may want to be sure that the black wire from the power source is connected to the black wire for the thermostat (black wire nearest the thermostat setting switch and closest to the power source wire). The black wire from the fan motor should be connected to the black wire closest to the fan motor's wire.
Aug 01, 2012 | Cars & Trucks
My newly installed Broan-NuTone attic fan worked fine for two days. Now it wont turn off, even though the temperature has dropped well (40 degrees)below the setting(100 degrees).
Jun 12, 2011 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
Jul 19, 2009 | Broan-NuTone N-8663RP Combination Light...
Concern of fan turning on and off to often
You have to set the thermostat due to the weater at that time. the main time is summer to blow out heat so set it higher to avaoid on and off situations.
Apr 09, 2009 | Dryers
Attic fans
I just fixed a Broan-353 with a similar problem - the fan was short-cycling, turning on and off within a minute or less.
These fans have a thermostat which is designed to turn off 10 degrees below where it's set to turn on. Apparently, one failure mode is this temperature delta stops working I've had this happen twice, each time after about 3 years.
Replacement thermostats are available from Broan for about $30 http://parts.broan-nutone.com/broan/Shop It's a 10 minute repair if you have easy access to the fan.
May 23, 2008 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
Blower in Attic not running
inside unit has fan control relay , either on control board or can be separate ,except for the 24 volt transformer and the t-stat the units operate separately concentrate totally on the inside unit this is where the problem lies
Oct 23, 2007 | Ruud UAMB Air Conditioner
Dryers Logo
42 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
