Question about Frigidaire FGF326AS Gas Kitchen Range
Rust on the stove
On the top of the stove it is white and those medel trays that go on top of each burner is rusted how do i get the rust off
  • steve
    steve May 11, 2010
    It would be simpler to replace them.
    About $4 each.
  • 99 Answers
Sand it down with sandpaper and repaint with some high temp paint.
Posted on Aug 09, 2009
How do I get rid of the rust on my appliances?
Remove rust with sandpaper, or wet and dry paper.
Then touch up with with the appropriate colour enamel paint.
Feb 24, 2015 | Stoves Ovens
How can i remove rust from inside of a top-loading washing machine?
If you have not all ready done so try something like iron or lime away through an empty load. if that does not work, most likely you are about to rust through the tub.. good luck
Jun 02, 2014 | Washing Machines
Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Jan 23, 2010 | Kenmore 24032\24036 Top Load Washer
Rust in interior of gas stove top
I have the same problem. This is the second stove to do that in our apartment building. I remember calling the Gas company last time, but I can't remember what the older employee told us why it happened. The only thing I can remember is it had something to do with the gas line..
Jan 07, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Rust in Kenmore washed clothes
Sounds like you have a bad drum bearing. I would guess that it's grees rather than rust although it will look like rust.
Please rate solution if helpful
Aug 23, 2009 | Kenmore 24032\24036 Top Load Washer
Outside door under water and ice tray is rusting--what to do??? admirial side by side
hi there,
most common ice tray is made of hard plastic materials that hold any defrosted water from evaporator,if rust occured this due residual water dried produced rust,it easy to remove rust,have it wipe bu anti rust remover mc compound,and wash carefully by detergent and water,on have rub it by sand paper w/ smooth size #
if your tray is made of metal,have it anti rust,wipe it out and paint it by epoxy aclyric spray paint,after dry washed by detergent and water in order to remove paint odor.have a nice day.
Apr 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
Gas Stove Top Burners
The burner are fixed only maintenace are to clean burner /clean holes and edge in order flow of gas good performance.At the back if you want make more good performance of your top burner clean the nozzle where the air and gas mix . Clean the nozzle w/fine niddle /sometime if will corrode with rust and dust to struck flow of gas.
Dec 23, 2007 | Dacor Preference SGM466 Gas Cooktop
Rust inside my washer
Use Oxylic Acid Crystals dissolved in hot water and test for color fast if applicable, carpets, clothes, washer, toilet, surfaces, etc. Oxcylic acid is a white crystaline acid which reacts specifically with Ferric Oxide, (rust) and oxidises the stain quite selectively. Few teasthingys in a small bowl of hot water and a toothbrush. Purchase cheap at local hardwares Hope this Helps Let me Know Ttech
Jul 24, 2007 | Kenmore 22422 Top Load Washer
Frigidaire FGF326AS Gas Kitchen Range Logo
260 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
