RV Comfort ZC Two Zone Thermostat 00 code - Heating & Cooling
Benimur
  • 6966 Answers
SOURCE: A thermostat versus an AC problem
"outside sensor error" is indicative of a Diagnostic error display, a feature where the device checks the functionality of each attached component. It would seem that your system has the optional "Outdoor Temperature Sensor" (probably P/N TSTATXXSEN01-B). The error then indicates that either that sensor is faulty or the hook up cable is unplug or defective. If you do not observed any critical changes in the comfort inside your home or the area that your system monitors/controls, then this only confirms that it is external and a sensor problem and does not affect the A/C and/or the variable speed furnace/comfort zone system. Normal faults could be the external sensor to cable connector/terminals being exposed to the elements and would require hard cleaning.
This sensor is not critical to the operation of the system and is optional.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 04, 2008
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
  • 17 Answers
SOURCE: I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Posted on Jun 25, 2009
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
Fifth wheel air conditioner has error code E1 on thermostat, how do i fix?
Somewhere in your manual you should have a table telling your what the codes mean. I have no idea. Once you find out I can most likely direct you in how to fix it.
Sep 02, 2014 | Dometic Rooftop RV Air Conditioner
I have 2 air conditioners on my Hampton trailer. I can't get my furnance to kick on. I have a R V Comfort .ZC duel control thermostat with zone 1 ,liveing room, and -Zone 2 ,bedroom, zone 2 will say gas...
I need to know what the furnace is doing .
Since you said furnace that's means force hot air and you have 2 Zone damper that's runs on 1 furnace ,correct?
If it's 1 furnace with 2 Zone is Zone 1 working
May 31, 2017 | Coleman Rv Air Conditioner Control Box...
I have a Comfort Zone CZ1500W showing an AO5 error code. I have 9 ohms across each element. The fan thermostat reads open. When I bypass it the fan runs, but no heat. The element thermostat reads
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
Dec 02, 2011 | Comfort Zone CZ1500WC Infra-Red...
Our Carrier Comfort Zone II thermostat, which has 2 zone readouts, currently shows a temperature of 00, as in zero zero, on one zone. That is the main zone for our home. Zone 2, for spare bedrooms, etc....
This .pdf file may be of help to you:
www.brivis.com.au/.../Carrier%20Comfort%20Zone%20II%20Owner's%20Guide.pdf
Perhaps you could get some help from Carrier Support here:
http://www.residential.carrier.com/support/index.shtml
I noticed they have an option of talking to an engineer, and perhaps they could explain how to reset or set the unit.
Hope this helps.
Sep 25, 2010 | Heating & Cooling
I have a 2003 HR Endeavor with 2 roof ubits. The front unit will cool and heat but the rear unit will not come on. The thermostat will not cycle to zone 2. Any suggestions?
Try resetting the thermostat. If you have the 5 button comfort control, turn the thermostat off. While holding down the mode and zone buttons, turn the tstat back on and hold the buttons until FF appears in the display. Release the buttons and then see if zone 2 is available. If not, remove the inner cover off the front air and remove the cover off the control box. Inside this box there are DIP switches (red stripe with white switches). Set the one for zone 2 to off and then reset the tstat as described above. Turn zone 2 back on and once again reset. If this does not work, you more than likely have a bad control board in the front unit as this is the one that controls all that.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
727 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
