Question about Icom Bp-8 Cm-8 Battery For Radio Shack Htx-202 Htx-404
HTX 202 LCD SCREEN
SCREEN IS SCRAMBLED WITH STRANGE FREQ READOUT.... STILL WORKS WITH TWO REPEATERS.... LOCKED ON THESE.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Reprogram your Radio
Posted on Jul 11, 2016
Sanyo dp42848 black spots and scrambled screen
Black spot means the LCD panel is faulty. Its better to go for new tv than rearing this one.
www.electro-medical.blogspot.com
Oct 07, 2015 | Sanyo DP42848 LCD TV
How do i get i n h off of display of my radio shack htx 202
HTX-202 (190-1120) Error Codes Faxback Doc. # 15722 Your transceiver has two error code displays. Refer to the following for an explanation of each error code. Er1: INTERNAL RAM ERROR Er1 indicates the transceiver has detected an error in its battery-backed up operation memory. This is the most commonly caused by a low lithium backup battery, but can also be caused by static discharge, or a physical shock. To clear the error-- 1. Turn off the unit. 2. Press FUNCTION and CLR (the D key). 3. While holding these keys, turn unit on. This will reset unit and clear memories. If the transceiver frequently displays the error, have the battery replaced by an authorized Radio Shack service center. ER2:PLL UNLOCK ERROR Er2 indicates the transceiver's PPL section has unlocked. Have the transceiver repaired by an authorized Radio Shack service center. (/ir-07/31/95)
Nov 01, 2014 | Radio Communications
HTX 202 LCD SCREEN
this is what happened when the CPU's went on these units, radio shack replaced so many & never actually fixed the real problems
Apr 20, 2013 | Icom Bp-8 Cm-8 Battery For Radio Shack...
My screen is scrambled don't know if its the
if you can see the windows screen on start up and it looks ok and scambled when on desk top you may fine its needing driver updates,
if the screen is the same scramble at start up as in desktop screen then the lcd panel is at fault ,the videocard in from memory on the motherboard
there are chips along the top of the lcd inside the case,some times they fail and do the same scramble result,replace lcd panel and away you go,
try an external monitor yet?Misterdj
Apr 05, 2010 | Computers & Internet
The screen is scrambled at times. It seemed like
it's probably not the LCD, it is most likely the ribbon cable... it could be repaired or if not, replaced...
Nov 08, 2009 | HP Pavilion dv9720us Notebook
White line on screen easynote mv35-202
Replace the LCD screen. Its problem with the LCD panel.
Sep 07, 2009 | Computers & Internet
Scrambled LCD tv picture
I would think its a T-con bard fault its the main board for the screen over time they ware out from heat. this control the picture for the screen. they can go in many ways, black screen mixed or shadows even star screen and scramble type screen. and white lines and even half working only.
Jun 07, 2017 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Cobra 200GTL: Clarifier affects TX
Unfortunately, most people look to unlock the clarifier in radio's it is locked in.
From what I understand it is possible to lock it in that radio, however I do not know it because I usually unlock it in my radio's.
I also did a search, and asked a few people I know who are also very good with radio's and they do not know either. The only thing I found was this, and you have to pay this shop to do it.
http://cobraworxshopz.com/12.html
Feb 02, 2009 | Cobra 200 GTL DX 4-Channels Base CB Radio
Scanner(POLICE) Question
Hi, using the manual button, step to channel 1 and enter your freq. including the point then press the E button. You might have to step to the next channel using the manual button again. Enter the next freq. and repeat. WX is the weather bands. Lockout is for locking out a nuisance channel(as an example, if someone's mic stays keyed, and keeps the squelch open).Priority is for any channel whose conversations you don't want to miss, just press the button for the specific channel. That way any time someone keys up on your priority channel, even if it's on another channel talking, will go right to the priority one. Review gives you a readout of the freq you programmed into a specific channel. If you need new or extra freq's check here on this site.
http://www.radioreference.com/apps/db/
** Hope this helps you out, let us know,,, Mechanic
Feb 03, 2008 | Radio Communications
Icom Bp-8 Cm-8 Battery For Radio Shack Htx-202 Htx-404 Logo
64 people viewed this question
Top Icom Radio Communications Experts
peter0911
spencer hughey
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
