Question about Frigidaire Dryers
Frigidaire afinity dryer E 64 service code - Frigidaire Dryers
According to other research (and my final diagnosis of our dryer), this is often caused by "sticking keys" on the main control board (Frigidaire AP3851145). Not usually faulty heater coils. The part is available online from $110 to $250. Not real easy to change out, but doable if you are a handyman.
Posted on Aug 07, 2013
  • Nicholas White Aug 07, 2013
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: My frigidaire dryer is showing E 64 error code, what does that mean?
    Hello florekedward - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. If I was in your position, I will highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing
    Posted on Mar 05, 2013
    E 64 code on a Frigidaire affinity dryer, but still getting heat. What could be the problem?
    that has three sets of coils in it,one of them is bad this is most likely why you still have heat,i've seen it a few times,change out the heater box,go here and look at the last picture,you'll see the three sets of coils one of them is broken,just order your heater box for your model number off of your dryer.change out the heater box
    https://www.appliancezone.net/134792700-frigidaire-dryer-heating-element-replacement/?gclid=Cj0KCQiAvrfSBRC2ARIsAFumcm_UzfGwntvtSVc9IDruzrS145S-0pcaF2W7iBwEOgT2y1r4boAgEPAaAoi4EALw_wcB
    Jan 04, 2018 | Frigidaire Dryers
    Whats the difference between e10 and e11 error codes on frigidaire afinity f/l washers?
    Thank you for your post, greg aguilar!
    Both error codes "E10" and "E11" stand for fill time is too long on your Frigidaire washer. This could be an issue with the water pressure coming into your washer the psi must be above 30 psi. If it is not you may need to correct the pressure issue. If it is check to assure that the hose is not kinked or blocked. You may need to replace the water inlet valve, pressure sensor, or control panel. I would recommend having a professional technician come out to provide a proper diagnosis for repair. Hope this information is helpful to some degree. -Matt
    Nov 19, 2014 | Frigidaire Washing Machines
    Error code 64 comes on and dryer is not heating
    check the dryer vent lines and hose for to be clean in restart dyer to see if it work
    Apr 29, 2014 | Frigidaire Electric Dryer
    I have an error code 64 on my dryer. I am out of work doing chemo right now. can anyone tell me what the problem is
    If your Frigidaire Affinity dryer is beeping at you and giving you the "E64 CALL SERVICE" business, chances are you have a bad heating element. The good news is, with a screwdriver, a pair of pliers (a multimeter if you have one) and a new heater element you can fix this yourself and save a couple hundred bucks.
    Below I outline a step by step process to do this on the Frigidaire Affinity, but this guide may help with other dryers, as they basically all function the same way.
    A WORD OF CAUTION: You will be handling a lot of thin sheet metal components. Be careful as it is easy to cut yourself on them.
    First you'll want to unplug the dryer. Then disconnect the vent hose and the water feed (if applicable). Be sure and shut off the water valve first, or you'll have a mess!
    http://therandomfix.blogspot.com/2013/07/frigidaire-affinity-e64-error.html
    Apr 03, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
    Yes, I have a 2011 Frigidaire E-Code E-64, if it is the heating element how to change it
    Hello William, thank you for your post!
    An error code E64 is associated with the heater circuit in the open position. A technician would typically check the heater coils and connections for short circuits to the cabinet to determine if it is the cause of the error code. Depending on the readings, the heater and/or wiring will need replacing. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis to help reduce the risk of unnecessary parts. I hope this helps explain the error code you are receiving.
    Sep 07, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
    Mar 05, 2013 | Frigidaire Electric Dryer
    E 64
    Hello christinwogo - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. If I was in your position, I will highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
    Feb 28, 2013 | Frigidaire Affinity AEQ6000WH Dryer
    Geting an E 64 csll service
    Check heater coils andconnections for open circuits. Replace heater and/or wiring and retest.
    Jul 21, 2012 | Frigidaire Electric Dryer
    Is there a place online that lists the error codes for Frigidaire
    There are several websites with error codes listed. I have not seen any codes listed for frigidaire dryers. So I checked at Frigidaire.com had no luck there either. 800-374-4432 is their customer service number. I found codes for Frigidaire cooking products but nothing for dryers. Good luck.
    Jan 05, 2009 | Frigidaire GLGQ2152ES Gas Dryer
    Frigidaire Affinity dryer error code?
    HELLO,
    I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
    Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
    Dryers Logo
    96 people viewed this question
    Top Frigidaire Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
