Question about Samsung SCH-u340 Cellular Phone
Issues with samsung u340
I have 2 of these one is mine one is my husbands, with both of them the alarm clocks originally saved an entry and the alarms worked now on both of ours only one out of the 3 alarms work anytime we try to set the others you fill it out and push SAVE and it pops up NOT SAVED! have tryed reseting them turning them off and on. I just can't figure it out. And I also cant figure out if you can get ringtones or not on the thing or how to go about doing it. Any help with either problem would be great. Thank you.
  • jcollins9301 Mar 18, 2008
    Samsung U340.
    Harware V.U340.05
    Software V.U340.Z.J09
    First one alarm would not save, then two out of three alarms would not save, now none of the alarms work. They pop up with "Not Saved" instead of 'Saved" at the end of the alarm setting operation.
On the options menu for the alarms instead of clicking to reset a single alarm you must reset all alarms at once.. worked on mine anyway.. wish you luck
Posted on Nov 19, 2007
Go to tools then alarms right button with the sots on my phone will take you to options. Then hit reset all alarms it should reset then so you will be able to save. I kept hitting buttons until I figured this one out.
Posted on Jan 08, 2010
Thanks, def works!
Posted on Aug 21, 2008
I did what rossman said, go into the alarm menu, then click Options, and Reset All.
Posted on Aug 05, 2008
Rossman can you please walk me through this process of fixing my alarm problem? i am afraid to reset the one that works and i really need 2 alarms, one for me and one to wake my son up for school, thanks!! any help would be aprreciated!!
Posted on Apr 17, 2008
  • melandandy Apr 17, 2008
    rossman can you please walk me through this process of fixing my alarm
    help would be appreciated!!
How do I turn the alarm on model 14AV201 onn clock completely off.
maybe reading your manual tells about the alarm function .
Mar 13, 2016 | Audio Players & Recorders
How to set the alarm
Go to clock -> alarm tab -> click the plus button -> set information for alarm -> click save
Jan 17, 2016 | Samsung Cell Phones
We cannot change the time on the alarm clock we have tried mode buttons taken out the batteries still cannot change its a ascot alarm clock
Mine did the same thing but I had to Push the ALARM BUTTON to get it to work. I ended up throwing mine away....
Not worth the Aggrivation
Apr 08, 2013 | Audio Players & Recorders
How do i turn off the alarm on my Samsung galaxy mini
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
Oct 31, 2011 | Samsung Galaxy S GTI9000 Smartphone
Alarm does not work if phone is switched off
If you turn your phone off, the alarm will not work, just as if you were to remove the battery and power from your alarm clock, it would not work.
May 11, 2011 | Samsung Galaxy S GTI9000 Smartphone
Alarm icon is displayed in the center of the screen no matter what I do. All alarms are turned off. I've rebooted the phone several times including removing the battery. What else can I do?
I've had this same weird problem today but I think that I may have solved it.
1. Go to "Menu"
2. Go to "Settings"
3. Go to "Display and Light"
4. Go to "Widget". Among your widgets is one called "Analog Clock". Un-check it and Save the widget screen.
5. Go out of the Menu to the top screen (that has "dial", "contacts" and "menu" at the bottom.) Hopefully, the alarm icon is gone. However, the "Analog Clock" that displays the time in the widgets (opened by the small arrow on the left side of the screen) is also gone. Simply go back through steps 1-4 to get to the "Widgets" screen and check the "Analog Clock". Your Analog Clock should display and the Alarm icon should still be gone.
I know that this solution doesn't seem to make much sense because what does an Analog Clock have to do with an Alarm icon? It just seems to be a software glitch of Samsung.
Try it out and see if it works.
Aug 14, 2010 | Samsung Solstice SGHa887
The alarm clock on S5230 soemtimes work and sometimes it doesnot work, please help
Here's how you do it:
Menu--Alarms--Tap to create--Alarm Name and Alarm Time [the time you want the alarm to go off] (I'm sure you can fill that up)--Now here is the part where you are facing the issue--The Alarm Repeat--Now press the Week days Tab--Select Everyday if you want the alarm to repeat everyday or select alternate days--Click Save.
Now the alarm will go off according to your set schedule.
If you need more help on that do let me know.
Feb 07, 2010 | Samsung SGH-S5230 Cell Phone
My alarm will still go off after i turn it off, how can i fix it?
Completely clear your alarms w/ this 3rd part application called SKTools
Get the WM6 version for smartphone (if you have WM6).
It's a trial but it clears up to 6 entries. Use that and then get a 3rd party alarm clock like Gentimer
This is a known issue w/ Windows Mobile's native alarm clock.
Hope this helps,
Bill
Sep 09, 2009 | T-Mobile Dash Smartphone
Alarm goes off every day. Want to turn it off!
Under the heading ALARM are 3 buttons. One says RADIO, one says CD, and one says NATURE. If any of these buttons are selected, the alarm will go off. So make sure none are selected, and the alarm won't sound.
May 15, 2009 | Timex T601GT Clock Radio
Alarm clock
I had the same problem. Finally in frustration I did the following. Press MENU, then 6, then 4, then Options, then 3 (Reset All). This apparently clears all the alarm memory and my alarm settings would then save properly. I hope this helps you!
Oct 20, 2008 | Samsung SCH-u340 Cellular Phone
Samsung SCH-u340 Cellular Phone Logo
595 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
