Question about Nokia E63 C3 C6 E5 N8)
E63 battery discharging solution
Easy battery discharge
4 Suggested Answers
vascotech
  • 93 Answers
SOURCE: nokia 8800 discharging prob
Nokia 8800 has the worst battery ever. Its a known issue. You need to have your phone flashed at a nokia service center, and get the new 8800 battery which ships on the 8800 sirocco BL6X.
Posted on Jan 24, 2008
ViscamTech
  • 528 Answers
SOURCE: battry discharge for nokia 1200
Insert a new battery.
Posted on Jul 31, 2009
ashlocked
  • 1140 Answers
SOURCE: im trying to fix my
by using tester,check the voltage if there's a shortage. try to check/clean light/keypad ic/coil,use a magnifying lense to trace it some components are still corroded. use ultra sonic solution to clean the entire board. also keypad flex as well if some parts are broken or damage...
hope it helps..
Posted on Jun 03, 2011
Fan don't stop and discharge battery
Sounds like a bad temperature sensor. Fairly cheap and easy to replace. Could also be a bad relay but I would start with the sensor first.
Aug 17, 2012 | 1997 Plymouth Neon
My phone is not in use these days but it gets discharged only after few hours needs solution
you need to change your battery, normally we do mistake when we dont need of mobile we leave battery inside of mobile which is not correct method that kills battery. this is what happen to you. so now solution is change the batery and new one charge switched off mobile up to 8 hours.
Jun 19, 2012 | Nokia E63 Cell Phone
My 5 WEEK OLD nokia e63 won't turn on. the d-pad lights up along with the screen (black) but it won't do anything else... HELP!
Before you go to NOKIA CARE please check the battery.It may be discharge to 2.8v. If the volt is less than the phone wont start up.I've experience this kind of problem many times and I solved it by backing up the battery by eliminator.So you can try it or if you have other battery which can insert/in same type try to put it and start.Thanks for visiting fixya
Aug 26, 2011 | Nokia E63 Cell Phone
Im trying to fix my nokia e63. it fell in the water. i opened it and cleaned it with methyleted spirit and dried it with a hot air station. now if i insert the battery, it lights the keypad leds and...
hope it helps..
Jun 03, 2011 | Nokia E63 Cell Phone
No network, battery discharging. i have only heat d network ic wth hot air
Try changing the network mode to automatic if it's manual and vice versa. Also check whether your SIM is still working by inserting in to another mobile phone.
If these are not working then could be problem with the phone itself.
Feb 28, 2011 | Nokia E63 Cell Phone
How can I make my digital camera battery last longer?
On every electronic that use a cell battery, that need to be charged and discharged after every use.
The very common easy steps on how to make your battery life last longer is just practice the complete the charged/discharged cycle of the battery.
You nee to at least once a wee to completely discharged the device battery, and charge it on the prescribed charging hours. Do not exceed on the number of hours the battery has to be charged.
Hope this initial information/idea helps. Let me hear from you again for any other instructions.
Thanks
Apr 06, 2010 | Nikon Coolpix 4600 Digital Camera
Overheating and battery runs down within 3 hours
Your phone is going through a process called panel over heating and battery discharge.
what to do.... remove the battery and take it to an experience repairer to fix it for you.
Feb 17, 2010 | Nokia E63 Cell Phone
Battery life only last one full day on normal usage n web surfing and music and video
The battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and the maximum battery capacity reduces with age and use.
You need to purchase a new battery.
Nov 25, 2009 | Nokia E63 Cell Phone
Plugged in not charging
I had the same problem in my laptop and it got solved by taking out the battery and placing back again...
Aug 14, 2009 | Acer ASPIRE 3680-2022 Notebook
Fully charge the Mobilepro battery
No. Lithium Ion batteries prefer a partial rather than a full discharge. Repeated full discharging robs the battery of its capacity (useful life), the Lithium Ion battery prefers shallow over repetitive deep discharge cycles. Besides cycling, the performance of the Li-ion is also affected by aging. Capacity loss through aging is independent of use however the capacity is affected by both aging and usage. Battery wear-down on lithium-based batteries is caused by two activities: actual usage or cycling and aging. The wear-down affects by usage and aging apply to all batteries but this is more pronounced on lithium-based systems. The Li-ion batteries prefer a shallow discharge. Partial discharges produce less wear than a full discharge and the capacity loss per cycle is reduced. Simple Guidelines to extend useful life of the battery Charge the Li-ion often, except before a long storage. Avoid repeated deep discharges. Keep the Li-ion battery cool. Prevent storage in a hot car. Never freeze a battery.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Nokia E63 C3 C6 E5 N8) Logo
16 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
