Question about Pyle 100/80 Watts Halogen Headlight Bulbs - PL9004 Pyle
How to change headlight bulb on a holden jackaroo
How do i change headlight bulb on holden jackaroo
Hi I have a 2002 Holden jackaroo 3 ltd and it will not start it just winds over wat could it be
Holden Jackaroo 2001 3.0 TDI 4JX1 Problems - YouTube
? 8:14
https://www.youtube.com/watch?v=xLySKue4HzM
Feb 22, 2013 - Uploaded by sandgroper111
Holden Jackaroo 2001 3.0 TDI 4JX1 Problems .... Hi there, currently own a 3.0 2002 lwb trooper 34K miles ...Missing: ltd
4jx1 cranks over but will not start - Jackaroo Technical ...
forum.australia4wd.com > ... > Jackaroo Technical
Nov 3, 2014 - 10 posts - ‎5 authors
Page 1 of 2 - 4jx1 cranks over but will not start - posted in Jackaroo Technical: Hi all, this is my first post so ... Holden at Pennant Hills Syd diagnosed a cracked cylindar head. ... I took the car into an auto elec at Alexandria who diagnosed No 3 injector faulty. ... I have a similar issue with my 2002 4JX1. 4jx1 rough idle, wont rev above 2500 rpm and wont ...
Apr 16, 2013
Oil Rail Pressure Sensor Valve Rebuilding for 4JX1 ...
Apr 22, 2012
Diesel Jackaroo hard to start - Jackaroo Technical ...
Oct 9, 2011
More results from forum.australia4wd.com
Missing: ltd
Nov 17, 2015 | Holden Cars & Trucks
My Holden jackaroo 2001 model headlights are not working, high beam is working fine. What could be the problem?
how are the headlight globes ?
there usually are two filaments in the globe if the low beam filament blows in both headlights high beam will work but low beam may not.
Sep 17, 2015 | Holden Cars & Trucks
How to adjust clutch on Holden jackaroo
free play at the clutch fork 3/16 mininum
Jul 05, 2014 | 2003 Holden Jackaroo
Indicators and hazards not working on 99 jackaroo
flasher relay is usually under the hood. Look for a black plastic box near the fender
Mar 18, 2014 | Holden Cars & Trucks
Holden jackaroo turbo diesel 2000 oil leaking into coolant can't seem to find where?
check the radiator .if it is getting in there.change your radiator.as it is your oil cooler part of it that is leaking.
Dec 10, 2013 | Holden Cars & Trucks
Holden jackaroo manuals
Did you pull the fuses and look at them? If you just stuck a probe in there you will get power even if the fuse is bad.
May 07, 2017 | Cars & Trucks
Fan belt diagram Holden jackaroo 1999 v6
Check with your local parts hopuse to see if they have the DAYCO belt routing booklet. We have it here in pdf for USA models only.
Jun 28, 2012 | 2003 Holden Jackaroo
Pyle 100/80 Watts Halogen Headlight Bulbs - PL9004 Pyle Logo
131 people viewed this question
Top Pyle Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Pyle Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
