Question about Vantec NexStar HX4 NST-640SU3-BK Black Quad Bay HDD Enclosure
Vantec hx4 The entire tower will randomly unmount then moments later remount themselves. Running late 2012 mac mini over USB3. I have two of these 4 drive units and both have the same issue
What Macs will be able to run macOS Sierra?
Macs that are compatible with macOS Sierra:
  • iMac (Late 2009 and later)
  • Mac mini (2010 and later)
  • Mac Pro (2010 and later)
  • MacBook (Late 2009 and later)
  • MacBook Air (2010 and later)
  • MacBook Pro (2010 and later)
Sep 25, 2016 | Apple macOS Sierra
I recently had a hard drive issue with my mac so I had to get a new one. I had also lost my old boot disk so I needed to do it by usb. But the problem is that I need a Mac OS to make an OS X Yosemite
You can put a Mac dmg on a usb using ubuntu.
http://askubuntu.com/questions/225820/how-to-create-a-os-x-mountain-lion-bootable-usb-drive-on-ubuntu
Feb 05, 2015 | Hard Computers & Internet
C07K1317DWYL confirm valid serial number or not
According to appleserialnumberinfo.com that is a valid serial number for a late 2012 model Mac mini.
Sep 04, 2014 | Apple Mac Mini Desktop
Mac serial numbers C07M3AV8DWYL
According to the serial number, the late 2012 Mac mini's maximum Resolution: Up to 2560 by 1600 (Thunderbolt) or 1920 by 1200 (HDMI). However, this mini does not have a slot loading DVD drive.
The last mini with a slot loading drive was made in 2010. That model's maximum resolution is Up to 2560 by 1600 (Mini DisplayPort) or 1920 by 1200 (HDMI)
Aug 20, 2014 | Apple MAC MINI 266GHz Intel Core 2 Duo 8...
I can not update my mac to 10.9
Hard to say without knowing exactly what Mac you have and what specs, but most likely reason would be your system doesn't meet the requirements (From Apple support site) - To install Mavericks, you need one of these Macs:
  • iMac (Mid-2007 or later)
  • MacBook (13-inch Aluminum, Late 2008), (13-inch, Early 2009 or later)
  • MacBook Pro (13-inch, Mid-2009 or later),
  • MacBook Pro (15-inch or 17-inch, Mid/Late 2007 or later)
  • MacBook Air (Late 2008 or later)
  • Mac mini (Early 2009 or later)
  • Mac Pro (Early 2008 or later)
  • Xserve (Early 2009)
Your Mac also needs:
  • OS X Mountain Lion, Lion, or Snow Leopard v10.6.8 already installed
  • 2 GB or more of memory
  • 8 GB or more of available space
Jan 18, 2014 | Apple OS Computers & Internet
I am running OS X 10.4.11 and would like to upgrade my operating system?
Please provide more information.
To what would you like to upgrade it?
Since OSX Mavericks was just announced, I'm going to assume that's what you're wanting to upgrade to.
Not all Macs can run Mavericks.
Mavericks Capable Macs
Mavericks, like its predecessor Mountain Lion, requires one of the following Macs with at least 2 GB of RAM and 8 GB of available hard drive space:
  • iMac (Mid 2007 or newer)
  • MacBook (Late 2008 Aluminum, or Early 2009 or newer)
  • MacBook Air (Late 2008 or newer)
  • MacBook Pro (Mid/Late 2007 or newer)
  • Mac mini (Early 2009 or newer)
  • Mac Pro (Early 2008 or newer)
If your Mac isn't one of the ones listed above, you won't be able to upgrade.
If you have an iMac, MacBook, MacBook Pro, or Mac mini model that was originally released in Early/Mid 2006, the latest version of Mac OS X your system supports is Snow Leopard.
http://store.apple.com/us/product/MC573/mac-os-x-106-snow-leopard
Oct 23, 2013 | Computers & Internet
I removed the back up drive from my iMac with out reading directions; just unplugged it! Now I replaced the line into the USB and it is not working and not shoiwng up on the computer. What do I...
Before you unplug an external hard drive, you need to unmount it first. If you don't, you can cause all kinds of problems.The term "unmount" basically means to prepare a drive to be unplugged from the Mac. In addition to external hard drives, "thumb drives" a/k/a "jump drives" as well as some cameras need to be unmounted before they are unplugged.When you unmount a drive, Mac OS X checks to see if you have any open files that are stored on that drive. If you do, the drive cannot be unmounted. This is a safety feature because if drive is removed with open files on it, the application that is using those files can become confused and you can lose or corrupt your data.
If you unplug a hard drive that has not been unmounted, Mac OS X will pop up a box with a red Stop icon and a message that you shouldn't have done that. Nice info, but a little late at that point.
I'm not saying that you will lose data every time you unplug a mounted drive, but the danger is there. I recently worked with someone who had his iPhoto Library on an external drive and he never unmounted the drive before unplugging it. It wasn't a problem for a long time but one time he opened iPhoto and all of the photos were missing.
Unmounting a drive is easy. There is an Eject icon to the right of the drive name in the DEVICES section of a Finder window. Just click that icon.
If you have multiple partitions to unmount, you can hold down the Option key when you click the Eject icon to unmount them all at once.
I thought about it and did some looking and I couldn't find anywhere in Mac OS X that states the need to unmount before unplugging, other than the big Stop icon you get after the fact. I don't think it is something you are likely to think of on your own, either. But now you know.
Oct 07, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
Vantec nexstar will not mount as removable
On windows seven there is no eject or remove safely in the main menu. Use mouse click <START> <Devices and Printers> find the device then right click and then select <Eject> or <Remove Safely>
Voil? you now can remove device without having to shut down computer.
May 18, 2017 | Vantec Nexstar Computers & Internet
I have a WD MyBook Essential 1TB external hard drive installed with my Mac OSX 10.5.8. The drive is only being used for Time Machine and my iTunes backup. The drive will randomly unmount itself and I get...
I would suspect that either the USB cable or port is the problem. Change the USB port (On the Mac or on the WD MyBook (I don't know if it has more than one USB port) that the cable is connected to and see if that improves the situation, if it still happens change the USB cable. Hope this helps.
Mar 22, 2011 | Western Digital My Book Essential 1TB...
Vantec NexStar HX4 NST-640SU3-BK Black Quad Bay HDD Enclosure Logo
82 people viewed this question
Top Vantec Computers & Internet Experts
Willem.
Willem.
Piyal Perera
Piyal Perera
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
