Question about Uniden Radio Communications
Will recive but will not trasmit uhf - Uniden Radio Communications
    Novelist:
  • Uniden Expert
  • 500 Answers
Can you give details with the model#. is it a dual band VHF/UHF
will it RX UHF etc..
Posted on May 07, 2013
I Have 2 recivers and 4 mics but can't use all 4 only 2 works
A wireless mic receiver will only reliably work with one mic at a time. For that reason, you need to have 4 receivers in order to use 4 mics simultaneously. You could switch back and forth between mics by setting them to the same frequency and turning them on and off, but they will not work reliably if they're both on at the same time.
Nov 10, 2013 | AKG SR40 - UHF Receiver SR4054 Microphone
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
Other room remote changes channels on BOTH TVs
turn off the uhf from you reciver in main menu set up funcion remoto control
Apr 07, 2010 | Toys
Hi the coaxal for the tv antenna is missing? i never had it. I been searching for an atenna to work? only to find out that the tv should of had that equiped on it. what should i do or how can i get the...
The company probably will not send it.You can buy it at any store walmart,radio shack etc.Of course you need a tv antenna for uhf. The term "hdtv antenna" is not of use in this case,as all modern uhf antennas are desing for DTV. Sometimes depends on your needs:general receive,one direcition recive (yagi or directional)etc. In other worlds you need an antenna and a coax cable,nothing else.
Jan 18, 2010 | Proscan 37LC30S60 TV
The dishnetwork. Sighn just dances around the screen I push select and nothing happens
This sounds like this may be an issue with your tv 2, make sure your remote is in sat mode by pressingthe sat button. then select, if still nothing take your remote to the recvr and look on the back of the recvr to make sure the uhf ant. is standing straight up if not, straighten and try remote functions. if you stillg et no responce there could be other issues that are simple to fix depending on what kind of equipment you have. you can call 800-333-3474 for assistance or reply with recvr name or model #.
Nov 16, 2009 | DISH Network IR Remote Control
Eo you recommended change the trasmition oil at
Yes, typically the recommended change interval is about 60-70K miles. Check your owners manual, it will tell you the exact interval.
Oct 15, 2009 | 2005 Toyota Matrix
Dish Network not working all... lights up but nothing else!
call dish network. they have all the information you could possably need.
their phone number is inside your recivers manual
Aug 19, 2009 | Universal Remote Control Dish Network...
Radios will not trasmit
The Motorola T-6510 uses FRS-GMRS frequencies the TK-3130 uses 2 UHF frequencies. Unless you had the radio custom programmed to match the GMRS frequencies it will not work.
May 04, 2009 | Motorola Talkabout T5100 (14 Channels)...
1992 toyota pickup need to change the cluch. is there a easy way to do this.???
no easy way.you will need a jack and stands metric tools disconeck batery remove starter and drive line remove shifter ther are 6 bolts you can axis them from the inside of truck by removeing the shifter boot.place a jack under the trasmition remove the trasmition mount and then remove the 6 bellhouseing bolts 14.mmbut first disconeckall wires from the tansmition after all this is you may need help to lower the trans.6 12mm bolts hold the cluch inplace remove and replace cluch.repet proses should take 3hrs to do this
Apr 16, 2009 | 1992 Toyota Pickup
Radio Communications Logo
71 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
